kellyv8 Posted May 25, 2009 Share Posted May 25, 2009 i have bought a decarden prop that i was assured was from a landrover but i cant seem to find an output flange to suit. the end that bolts to the output flange is 125mm in diameter and about 108 mm between holes centre to centre the length of the prop seem a bit short too but thats not such a problem. so if anyone can let me know which vehicle its from it would be much appreciated Quote Link to comment Share on other sites More sharing options...
TD5 power Posted May 25, 2009 Share Posted May 25, 2009 hi if it is land rover then it is likely to be the front prop shaft from a discovery 2 Part no for the transfer box flange is STC4379 and STC4858 for the diff flange these are disco part numbers you would have to check they will fit you truck HTH matt Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted May 25, 2009 Author Share Posted May 25, 2009 cheers for that but ive tried that one and its a smaller diameter Quote Link to comment Share on other sites More sharing options...
ciderman Posted May 25, 2009 Share Posted May 25, 2009 The Series 3 stage 1 V8 had a double cardon prop that had a large output flange on the transfer box . Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted May 25, 2009 Author Share Posted May 25, 2009 dont suppose you know the diameter Quote Link to comment Share on other sites More sharing options...
cipx2 Posted May 26, 2009 Share Posted May 26, 2009 See if your prop fits the description and looks like on http://landroverorphanage.com/shop/article...-Propshaft.html or like http://www.thexmod.com/item_detail.asp?id=1242 The flange that goes with those is this: http://www.landroverorphanage.com/shop/art...id%3DFRC9374%26 The PCD on your prop seems to be like described here: http://www.d-90.com/tech/cv1.html - maybe using a spacer would be the way to go as you say the prop is bit short. If no luck then get a deflange, these are specifically designed to go with decardens no matter the application ... Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted May 26, 2009 Author Share Posted May 26, 2009 thats the one thanks very much for all the help Quote Link to comment Share on other sites More sharing options...
