foggy3061 Posted May 26, 2009 Share Posted May 26, 2009 Could someone help with the land rover part numbers, for the following parts for a rear axle from a Discovery (1995, 300 tdi, 24 spline, ABS). •Stub axle •Stub axle gasket •Stub axle wiper seal / locking plate •Wheel bearing nut •Brake calliper mounting bolt •Diff to axle casing gasket •Diff to axle casing nylock nut Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 From my Microcat. hth Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted May 26, 2009 Author Share Posted May 26, 2009 From my Microcat.hth Thanks again western, top man! Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted May 26, 2009 Author Share Posted May 26, 2009 Don't suppose you know the part number for item 10 too - think its called a locking plate/seal? Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 Don't suppose you know the part number for item 10 too - think its called a locking plate/seal? Yep, that's FRC2310 non-abs brakes. Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted May 26, 2009 Author Share Posted May 26, 2009 Yep, that's FRC2310 non-abs brakes. Hmm, it has ABS, and yet when i stripped the axle it had the above item fitted, is there a ABS version of the same item? I think it must be there to keep crud off the ABS sensor ring. Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 Yep, ABS version is FTC1378 for front & rear brakes with ABS Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted May 26, 2009 Author Share Posted May 26, 2009 Yep, ABS version is FTC1378 for front & rear brakes with ABS Excellent, thanks again! Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 happy to help. Quote Link to comment Share on other sites More sharing options...
