NickHodgson Posted May 26, 2009 Share Posted May 26, 2009 Hi I have a new ERR6700 300tdi Injector Pump and would like to use it to replace the one on my 300tdi defender. My defender does not have EGR or immomilisation. If I remove the black box on the back of the new pump for immobilisation can I replace it with the normal plunger switch? Also can I remove the bit on the top of the bracket that the thottle cable connects to that I assume is for EGR? There also seems to be another spring arrangement connected to the side of the pump and the bracket that connects the throttle cable - any ideas what it is for? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 you will find the same fuel shut off soleniod underneath the EGR black box. without a phot of the extra spring & bracket, it might be fitted with the hand throttle parts for PTO or hydraulic winches. Quote Link to comment Share on other sites More sharing options...
