tommac Posted May 26, 2009 Share Posted May 26, 2009 As the title says really- the defender has started to leak oil very heavily, never had any oil loos previously- having investigated briefly it appears to be coming from two places next to each other- the lift pump gasket is weeping- i changed the pump 6 weeks ago so obviously distrubed something- i will replace the gaskety but more of a problme is the brake servo pump (next to the lift pump? i think this is it) has a major oil leak from the join to the block- is this as straight forward as a new gasket? Any tips/advice much appreciated! Cheers, Tom Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 new gaskets on each should cure it, check for cracked or missing bits of the mounting flange on the lift pump & vacuum pump. Quote Link to comment Share on other sites More sharing options...
tommac Posted May 26, 2009 Author Share Posted May 26, 2009 new gaskets on each should cure it, check for cracked or missing bits of the mounting flange on the lift pump & vacuum pump. Thanks Western- will order a couple of gaskets in that case! Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted May 26, 2009 Share Posted May 26, 2009 I replaced my vacuum pump as it had a little hole in the end which was pee-ing oil all over the place. I didn't replace the gasket though, I just applied some sealer to the existing gasket and all is good again. Possibly a bit of a botch job, but I only bought a second hand vacuum pump which didn't come with a gasket. Quote Link to comment Share on other sites More sharing options...
