A Twig Posted May 26, 2009 Share Posted May 26, 2009 As it says, is it a difficult process? Would it cost a lot to get someone to do it for me? i.e. are the parts more expensive than any labour costs involved? Just out of interest out the mo, as I have heard rumours of some cheap PTO stuff available... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 26, 2009 Share Posted May 26, 2009 The PTO is a doddle to fit - what are you planning to drive from it? Its the rest of whatever set up your are intending to use that will probably be more involved. Quote Link to comment Share on other sites More sharing options...
A Twig Posted May 27, 2009 Author Share Posted May 27, 2009 At the moment, just a winch, but there may be other uses soon. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted May 27, 2009 Share Posted May 27, 2009 Remove blanking plate and spacer on transfer box Using spacer that came off, replace it along with PTO. Use blue Hylomar IIRC and then bolt it up. It is important that you use the spacer that you take off your vehicle in the first place as there are some scary differing build tolerances and it might whine. Take some measurements and drill hole for PTO lever. Fit lever and fill with oil. If you find a series landie, the red knob will also fit the PTO lever instead of the standard black one.( if you fancy) Is it a 110 or 90 - if it's a 110 you may have to remove the exhaust hanger and make up a custom one - v easy - just get the bits from Halfrauds! Hardest bit is holding/supporting the PTO whilst you get bolts in as it is quite heavy and awkward to hold in place. HTH James Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 27, 2009 Share Posted May 27, 2009 A syringe is good to fill it with oil as there isn't much room through the access panel. If you are fitting a PTO winch have a search on here about rotating the drive to give more ground clearance. (Unless of course you mean a Hydraulic PTO winch...) Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted May 28, 2009 Share Posted May 28, 2009 Anyone have photos of Defenders fitted with rear pto's ? I'm interested to see how the pto propshaft is arranged to clear the ''A'' frame assembly and what is done to beef up the flimsy rear crossmember in order to mount the various bits of equipment that Series vehicles were capable of driving. Bill. Quote Link to comment Share on other sites More sharing options...
