Sean Thomas Posted May 26, 2009 Share Posted May 26, 2009 Hi All, Finally got the bulkhead on an in the correct position, much shimming required. now the next part of the rebuild is how to route the brake pipes for the front axel, rear is quite easy. I can see how they are meant to attach to the flexible hoses. but where the battery holder is mounted on the chassis is a bit busy. Oh and the old chassis had a bodge job done on the pipes so I can not use that as a guide . Thanks all. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 26, 2009 Share Posted May 26, 2009 Single line or dual line (servo) brakes ? Les. Quote Link to comment Share on other sites More sharing options...
tuko Posted May 26, 2009 Share Posted May 26, 2009 where the battery holder is mounted on the chassis is a bit busy. What do you have there? To more easily answer Les question, there should be a union where several brake pipes connect to in the relative location of the battery holder. Can you tell us how many lines are connected to it, is it 4 or 5 ? Todd. Quote Link to comment Share on other sites More sharing options...
Sean Thomas Posted May 29, 2009 Author Share Posted May 29, 2009 What do you have there? To more easily answer Les question, there should be a union where several brake pipes connect to in the relative location of the battery holder. Can you tell us how many lines are connected to it, is it 4 or 5 ? Todd. Sorry, single line, no servo. Quote Link to comment Share on other sites More sharing options...
