Hillbilly Raider Posted March 13, 2006 Share Posted March 13, 2006 seen this... is it a good deal? coolfun refridgerator/freezer 40litres 230volts APC 65watts ART 6% at 20 OC ambient temperature 10%at 32 oc ambient temperature, both at 5oc intterior temperature. Temp range +10 oc -15 oc. AC compressor, ali rollbond evapourator, stacticlly ventilated wire condensor. cabinet coated in sheet steel base and upper components plastic. £189. 95. Towsure. ????????????????? Quote Link to comment Share on other sites More sharing options...
headhunter Posted March 13, 2006 Share Posted March 13, 2006 seen this... is it a good deal?coolfun refridgerator/freezer 40litres 230volts APC 65watts ART 6% at 20 OC ambient temperature 10%at 32 oc ambient temperature, both at 5oc intterior temperature. Temp range +10 oc -15 oc. AC compressor, ali rollbond evapourator, stacticlly ventilated wire condensor. cabinet coated in sheet steel base and upper components plastic. £189. 95. Towsure. ????????????????? Current draw appears to be 5.42 amps (65watts divided by 12 volts) which is fairly high compared to a 45 litre Engel which I think only draws about 3.2 amps once at cooled temperature (which you can reach at home using mains 230/250 volts). If you have plenty of battery reserve you should be OK, as for price, a similar size Engel is around £600 new, so the Towsure coolfun price looks reasonable, especially for occasional weekend use, not sure though for a long expedition. John Quote Link to comment Share on other sites More sharing options...
MogLite Posted March 13, 2006 Share Posted March 13, 2006 This one ? Mains only ? Running it in a vehicle through an inverter wouldn't be very efficient. 230V all the time isn't a great idea - what happens when you hit water !! How do you strap 'em down ? I'd PM HonitonHobbit and see what OEC sells Quote Link to comment Share on other sites More sharing options...
tombraider110 Posted March 13, 2006 Share Posted March 13, 2006 That looks like a flat battery waiting to happen. Get an Engel i left mine on for 4 days at billing last year without starting the motor and it still started with out a problem. And the beer was lovey and cold Quote Link to comment Share on other sites More sharing options...
Dale Simpkins Posted March 13, 2006 Share Posted March 13, 2006 That looks like a flat battery waiting to happen. Get an Engel i left mine on for 4 days at billing last year without starting the motor and it still started with out a problem. And the beer was lovey and cold Yep, Engel is the way to go. Got ours at Billing last year, but it wasn't 600quid, got ours for 400quid cash deal. A LOT of money, but definately worth it! I can give you the name of the company we bought ours from if you want. Quote Link to comment Share on other sites More sharing options...
