ollie nz Posted May 28, 2009 Share Posted May 28, 2009 Hello all,I have just had to replace the FUEL BLOCK on my 03 TD5 90 Defender,117ks,due to leaking diesel,anyone else had a similar problem,cheers Quote Link to comment Share on other sites More sharing options...
ragerover Posted May 28, 2009 Share Posted May 28, 2009 Hello all,I have just had to replace the FUEL BLOCK on my 03 TD5 90 Defender,117ks,due to leaking diesel,anyone else had a similar problem,cheers yep common fault mine leked in to the gearbox and killed the clutch Quote Link to comment Share on other sites More sharing options...
ollie nz Posted May 30, 2009 Author Share Posted May 30, 2009 yep common fault mine leked in to the gearbox and killed the clutch thanks for that,glad I caught mine in time,cheers Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted May 30, 2009 Share Posted May 30, 2009 yepss same here mate! the thing abt it is that i couldnt find an o ring that fits good! cos usually that is the problem! had to buy whole thing gil Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted May 30, 2009 Share Posted May 30, 2009 yup they all do that after 100k. mine decided to leak after 120k. change the entire thing. not cheap considering that it's just the gasket or o ring that leaks. it's the fuel pressure regulator. Quote Link to comment Share on other sites More sharing options...
ollie nz Posted May 30, 2009 Author Share Posted May 30, 2009 yup they all do that after 100k. mine decided to leak after 120k.change the entire thing. not cheap considering that it's just the gasket or o ring that leaks. it's the fuel pressure regulator. Thanks Andrew Quote Link to comment Share on other sites More sharing options...
ollie nz Posted May 30, 2009 Author Share Posted May 30, 2009 yepss same here mate! the thing abt it is that i couldnt find an o ring that fits good! cos usually that is the problem! had to buy whole thinggil Cheers Gil,typical LR,not selling just the small part one needs Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted May 31, 2009 Share Posted May 31, 2009 its a landrover thing............you cannot understand!!! Quote Link to comment Share on other sites More sharing options...
101sean Posted June 1, 2009 Share Posted June 1, 2009 Just done mine, poxy fuel hose on cooler was jammed, stress of releasing it broke pipe off cooler The cooler pipes on early ones are only chemically bonded, coolers are stainless steel and plastic. A mate who works with stainless welded pipe back in, fine for a couple of days until end cap seal gave way. Got s/h replacement on way from breaker, they are £300 new So if doing this job on early one, don't strain the fuel cooler pipes. Later ones have a totally different cooler design (surprise, surprise ) Quote Link to comment Share on other sites More sharing options...
ollie nz Posted June 2, 2009 Author Share Posted June 2, 2009 Just done mine, poxy fuel hose on cooler was jammed, stress of releasing it broke pipe off cooler The cooler pipes on early ones are only chemically bonded, coolers are stainless steel and plastic. A mate who works with stainless welded pipe back in, fine for a couple of days until end cap seal gave way. Got s/h replacement on way from breaker, they are £300 new So if doing this job on early one, don't strain the fuel cooler pipes. Later ones have a totally different cooler design (surprise, surprise ) Very interesting,thanks Sean Quote Link to comment Share on other sites More sharing options...
GBMUD Posted June 2, 2009 Share Posted June 2, 2009 Mine went a couple of months ago, I looked at the possibility of changing the O-rings but my leak was from the pressure regulator diaphragm so I had to change the whole thing. 2004 model, 85k miles. Not cheap but quick and easy to do. Chris Quote Link to comment Share on other sites More sharing options...
ollie nz Posted June 2, 2009 Author Share Posted June 2, 2009 Mine went a couple of months ago, I looked at the possibility of changing the O-rings but my leak was from the pressure regulator diaphragm so I had to change the whole thing. 2004 model, 85k miles. Not cheap but quick and easy to do.Chris Thanks Chris Quote Link to comment Share on other sites More sharing options...
