defender dinky Posted May 28, 2009 Share Posted May 28, 2009 hi all, will 33/12.5/15 fit a standard defender 90, with standard suspesion, and what would i have to alter cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 29, 2009 Share Posted May 29, 2009 hi all, will 33/12.5/15 fit a standard defender 90, with standard suspesion, and what would i have to alter cheer's defender dinky They will fit, but will rub on arches off road. Width is the problem on that size. On standard offset wheels they will reduce your turning circle and you'll have to adjust your steering lock stops to stop them rubbing on the front radius arm. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 29, 2009 Author Share Posted May 29, 2009 They will fit, but will rub on arches off road. Width is the problem on that size. On standard offset wheels they will reduce your turning circle and you'll have to adjust your steering lock stops to stop them rubbing on the front radius arm. hi steveG thanks for reply defender dinky Quote Link to comment Share on other sites More sharing options...
