TD5 Handbrake Assemblies
disco_al
We are currently trying to supply a handbrake cable for a TD5 Disco. The cable that has come off has got a rubber grommet on the lever end, where it passes through the floor, the replacement has got a metal end, and as such, will not fit into the lever. (I take it the metal end is to try and cure the common earth problem they have?)
Looking at the microcat, the cable and the lever have been superceded to later numbers, has anyone else had this problem with TD5 levers and cables?
Do we need to replace the lever as well as the cable?
Cheers all.
