The Badger Posted May 30, 2009 Share Posted May 30, 2009 So then, fitting a TD5 dash on a 300 tdi bulkhead, it's all simular and I an at the stage that I just need to fit the top bit of dash... However, the TD5 metal dash bit, needs some kind of fitting point attached that lets the top bit attach? Anyone done this??? Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2009 Share Posted May 30, 2009 have a look at http://www.reedx.net/landrover/mods/2002dash/index.htm should help. Quote Link to comment Share on other sites More sharing options...
The Badger Posted May 30, 2009 Author Share Posted May 30, 2009 OR Can anyone tell me the distance off the bulkhead that the bracket needs to sit. This bracket, as a 300tdi bulkhead does not have it. Quote Link to comment Share on other sites More sharing options...
The Badger Posted May 30, 2009 Author Share Posted May 30, 2009 have a look at http://www.reedx.net/landrover/mods/2002dash/index.htm should help. Thats's it, again western you are a fountain of info, cheers, I ow you pints I managed to get a late style wiring loom that goes from a td5 dash to a 300 tdi engine, since mine is a a complete build up I can make the mod's as I go. Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2009 Share Posted May 30, 2009 happy to help, I've got Colin's site in my favourites, so finding the info was easy. good luck with the build up. Quote Link to comment Share on other sites More sharing options...
The Badger Posted May 30, 2009 Author Share Posted May 30, 2009 I keep on saying that I will ad some images, and I will say it again... Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted May 30, 2009 Share Posted May 30, 2009 Hi mate, Done this myself, I canabalised my old dash for the standoff pieces from the rear piece of tin and it all fitted just peachey. There is however one little tweak land rover made which I missed. The windscreen wipers on the TD5 are mounted differently the drive rod sitting below the wiper shaft where as on the older type it was above, this then means that the air vents dont sit properly. Regards Rob Quote Link to comment Share on other sites More sharing options...
The Badger Posted May 31, 2009 Author Share Posted May 31, 2009 Hi mate,Done this myself, I canabalised my old dash for the standoff pieces from the rear piece of tin and it all fitted just peachey. There is however one little tweak land rover made which I missed. The windscreen wipers on the TD5 are mounted differently the drive rod sitting below the wiper shaft where as on the older type it was above, this then means that the air vents dont sit properly. Regards Rob Ah, I might get this but I will find out today. As for the wiper motor, I have a TD5 wiper motor rod and all, the rod is shorter on this meaning you have to sit it in the same spot as if on a TD5 bulkhead. Now the 300 TDi bulkhead is lacking a bracket, but you can make one up as I have and it will sit nicely. I have also removed the brackets that are attached to my vent flaps and will attached the brackets that have come with the dash. That's weird on the drive rod, as because I got the whole set up, my spindle bit (what holds the cog) was the new oval shape, so I have switched these out to be the round type (really easy to do if anyone needs to do it), and both of them have the drive rod working from below? (not unless I fitted them wrong??? Quote Link to comment Share on other sites More sharing options...
