trickydicky Posted May 31, 2009 Share Posted May 31, 2009 hi can anybody explain the consiquenses of a worn rocker shaft on an angine ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2009 Share Posted May 31, 2009 Inability to set the correct tappet gap, tappet rattle - especially when the engine is idling (the top of the engine sounds like an old sewing machine). Depending on what engine you have - you may be able to rotate the shaft 180-degress and refit it. Only half the shaft tends to wear - the bottom of it, as this is where the pressure is during operation. If the shaft wears too much - the bushes inside each rocker also wear. Les. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted May 31, 2009 Author Share Posted May 31, 2009 Inability to set the correct tappet gap, tappet rattle - especially when the engine is idling (the top of the engine sounds like an old sewing machine).Depending on what engine you have - you may be able to rotate the shaft 180-degress and refit it. Only half the shaft tends to wear - the bottom of it, as this is where the pressure is during operation. If the shaft wears too much - the bushes inside each rocker also wear. Les. its a 19J Les can u rotate the shaft on them? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2009 Share Posted May 31, 2009 Yes Les. Quote Link to comment Share on other sites More sharing options...
