steering box re-build..
hi chaps..
on my defender i have a 6 bolt steering box.. there is nasty leak thats been getting worse over the past year.
it pretty bad now and the screw is tightend up as far as it will go..
beings the seals are buggerd and its loosing preasure.. will it be worth stripping it shoving new seals in.. would that cure the problem do you think?.
or would there be any exsessive wear in the components inside the box?
cheers sam
