BLACKJACKS Posted May 31, 2009 Share Posted May 31, 2009 i need some help big time no on my disco the fuel gauge is not reading anything the lights on saying empty ive checked all the wiring and cant find anything wrong . pulled the foat up and nothing. cleaned all the earths i can find still cant get it to work . now if i put a new foat unit on im going to snap the fuel joint on the top of the old unit so how do i fix these. is there a fuse or a relay for this gauge and where are they all fuses are looking ok so can any one help me please going bold after all my scratching of the head Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 1, 2009 Share Posted June 1, 2009 Have you checked the fuel gauge sender for continuity? Resistance values? Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted June 2, 2009 Author Share Posted June 2, 2009 Have you checked the fuel gauge sender for continuity? Resistance values? i wouldnt know what u mean or what to do where does the wiring loom go from the tank does it go in to the chassis or cant see where it goes to or is there a relay as ive no power bhind the clocks on the gauge so no power to the gauge what so ever has any one got any ideas ...... Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted June 3, 2009 Author Share Posted June 3, 2009 all sorted found the problem ............ Quote Link to comment Share on other sites More sharing options...
Lazzer R1 Posted August 19, 2009 Share Posted August 19, 2009 all sorted found the problem ............ Hi BLACKJACKS, I'm having the same issue. What was the resolution that you found? Quote Link to comment Share on other sites More sharing options...
