Desert Cat Posted June 2, 2009 Share Posted June 2, 2009 Does the ACE fluid to be replaced after X miles? Can I run this operation under domestic environment, or some equipment is needed? I had changed the "HI-Pressure PAS pipe" and topped up the steering reservoir with fresh PAS fluid. Looking into the ACE reservoir, fluid looks "muddier" than the fresh steering PAS fluid. Should I use a manual pump into the ACE reservoir, take out some "old" fluid and put some "fresh/new" fluid? No trace on RAVE regarding replacing ACE fluid... Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 2, 2009 Share Posted June 2, 2009 the maintenance check sheet will give you the clue. to have a quick look at it, follow the links in this thread: http://forums.lr4x4.com/index.php?showtopic=41733 Quote Link to comment Share on other sites More sharing options...
