CJRH Posted June 3, 2009 Share Posted June 3, 2009 Can someone please let me know which pipe goes where as I'm a bit confused! Cheers, Chris Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2009 Share Posted June 3, 2009 To many pipes on that for a Tdi filter. mine is like this your photo is a TD filter head. Quote Link to comment Share on other sites More sharing options...
CJRH Posted June 3, 2009 Author Share Posted June 3, 2009 Well that might explain it then At least the 200tdi filter is a lot simpler! By the way, you are super quick at drawing Cheers, Chris Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2009 Share Posted June 3, 2009 Can someone please let me know which pipe goes where as I'm a bit confused!Cheers, Chris my notes on here should help. on your filter head 1 to injection pump 2 to lift pump 3 from spill return 4 blanked off, not used rearmost bolt is the bleed screw centre bolt secures filter element to top & bottom castings. Quote Link to comment Share on other sites More sharing options...
CJRH Posted June 3, 2009 Author Share Posted June 3, 2009 Cheers again, I think I'll just get hold of a propper 200tdi filter assembly, will make life easier! Chris Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2009 Share Posted June 3, 2009 off a old Discovery would probably be the easiest to obtain. it will bolt straight on to the existing filters location on the bulkhead. Quote Link to comment Share on other sites More sharing options...
