freenelly Posted June 4, 2009 Share Posted June 4, 2009 Hi All My first post here , after an unfortunate Gearbox failure resulting in a £1100 repair bill for a recon i have sifted through this and other forums looking for posible weak points with my 2002 td4 Freelander. Gearbox well it is the Jatco auto and yes i did miss the oil change at 60k and it failed at 70k so i do feel guilty , looking around the question of the Crankcase breather came about so i changed it . The Lander wasn't suffering any of the symptoms i have read about but i think prevention is better than the cure , it is an easy job as mentioned on here by several of you . Are there any other points i should look out for ? i have done the oil and filter ,fuel filter have installed a k&n air filter i even changed the EGR Air Filter. What about the rear diff oil ? Regards Nelly Quote Link to comment Share on other sites More sharing options...
Blippie Posted June 19, 2009 Share Posted June 19, 2009 Our Camel gets a complete oil change every service - gearbox, IRD and rear diff. The TD4 gets services as per the service schedule - which often means top-ups rather than drain and refills. Have you checked your VCU? Cheers Blippie Quote Link to comment Share on other sites More sharing options...
freenelly Posted June 19, 2009 Author Share Posted June 19, 2009 Our Camel gets a complete oil change every service - gearbox, IRD and rear diff.The TD4 gets services as per the service schedule - which often means top-ups rather than drain and refills. Have you checked your VCU? Cheers Blippie Vcu Is that with the tipex test ? Quote Link to comment Share on other sites More sharing options...
