Air conndition kit Replacment
90_uae
Dear LR Members'
happy to see members from middle east and all over the world sharing ideas and thoughts
i'm from UAE Abu Dhabi. We know what does hot weather mean (52C) . i was going to order from http://www.eliteautomotive.co.uk/index.html air con kit today.
just wanna make sure is it realy cold .....for me i believe it should be cold because it manifactured by company in South Africa called Smiths and distrebuted by Dunair also in South Africa.
these under dash AC kit has been tested in California (USA) where Temp is same as ours ..........am i right ?? any body got under dash AC kit in real hot enviroment?? how it's running ?
i got (realy bad one ) the evaporator unit in the engine bay
two picture first will be mine and second what i'm looking to buy
happy to have idea's from gentlemen's :)
yours,
Ali
Welcome Ali.
Most here live in the UK. So the climate is not exactly making AC a must have. Almost any AC will cope with the temperature here (30 degrees max for a couple of days a year).
I hope some of the guys from South Africa or Australia can help you more.
Hi, can I ask what kind of price range these things are in? Would really like aircon in my IIB, as we are taking it to Portugal on the motorway, and am looking for some sort of aircon system.
regards
maarten
regards
maarten
Sorry guys
the picture sequence made some confuse
the second is mine i'm looking for the under dash one
Santalars: you right if temp only 30c max then any bad A/C ssytem will be fine ^_^ lucky you .
Maarten it's 945 pounds from eliteautomotive
Ali
Living in a country where A/C is a must I am surprised you can't just take it to any local A/C company and have them make up a system for you.
The only specialist parts would perhaps be the mounting and belt tensioning for the compressor.
Steve
Ali
Steve
cause u'm looking for OEM finish and making sure that i don't waste my $$
thats why i wrote the topics for ;) ............. if you didn't ask you will never know
when search on the web i don't come with result as the other people.
Western: thnx alot really i seach ebay didn't got these things
Ali,
I live in Barbados and had a 2004 defender double cab with the OEM version you're looking at... it was OK but not great by any stretch and certainly nowhere close to any of the japanese pick-ups... A friend of mine supplemented that OEM set-up with an additional aftermarket kit by one of the US companies like hot rod air.
