Thule Professional
What type of bars are you looking at and where did you get the part numbers?
I found this via Google http://www.thule.co.uk/appguide/yourDetail...SP=&tLocks= the bar looks like what is on mine but couldn't match up your numbers with the ones on the Thule site.
I got my set from Bearmach as a kit under a BM part number but I am sure they are branded Thule, they are sold as a universal set for Defender & Discovery and are adjustable to any width and will suit a standard gutter, are these what you are looking for?
I couldn't find the information I wanted on their website... In the past, Thule has recommended the high feet that can be seen in Mr Monster's pic. I bought the next lower size which put the bars closer to the roof. My 110 is of the older variety with the roof straightening on the outside so the crossbars almost touches these ridges, so I assume that it will be some air in between on a newer style roof. Anyway, they are fine for me since the bars are only used to support a roof top tent.
Lay something flat across the roof and measure down to the gutter. Mine is 20 cm from top of the straightening ridges to bottom of gutter.
I've got a set I used to have on my 90 that I don't use anymore if you're interested, from what I can tell in the pic, they're the same as bogmonsters. If they don't fit, obv you wouldn't have to buy them....
  • 2 weeks later...
