dasterdly Posted August 20, 2005 Share Posted August 20, 2005 hello, could wing mounted military whip type ariels be used to recieve a tv signal for a 12 volt tv/radio i have in the defender ? i dont really want to fit a caravan type ariel to the roof, or the wing ! but just a passing thought... or maybe there is something else i could fit, which would do the job, the tv has a radio built in as well.. cheers... Quote Link to comment Share on other sites More sharing options...
oli Posted August 20, 2005 Share Posted August 20, 2005 Hi, The arials are used to be between 2m and 2.5m long. This is the right lengt for a frequency of about 30 Mhz. TV Signals can be found from abt 48MHz (VHF), 180MHz (VHF III) to 470 MHz and above (UHF). The Military aerial does not fit to the most of this frequencies. It might work if you put an amplifier/converter between the whip aerial and you telly but I think this will not work good. bye Oli Quote Link to comment Share on other sites More sharing options...
dasterdly Posted August 26, 2005 Author Share Posted August 26, 2005 hello, it got me thinking when i saw a black and white portable tv in a secondhand shop, and it had the small loop arial attatched, but i guess that they must have some sort of amplifier in the tv circuit board. maybe i could run coils of copper wire round and round the landy until emmerdale tunes in ! cheers... Quote Link to comment Share on other sites More sharing options...
OrbitalPear Posted August 26, 2005 Share Posted August 26, 2005 Pretty much anything will work, just not as effectively as a real aerial. Why would you want to for Emmerdale? Quote Link to comment Share on other sites More sharing options...
dasterdly Posted August 27, 2005 Author Share Posted August 27, 2005 hello, in reality i wouldnt, but i couldnt think of another tv program !! cheers... Quote Link to comment Share on other sites More sharing options...
Smudge 4x4 Posted September 1, 2005 Share Posted September 1, 2005 It does work, the sound is spot on yet the picture quality is poor. They are also affected by the elements a lot as the sway around !! Quote Link to comment Share on other sites More sharing options...
dasterdly Posted September 1, 2005 Author Share Posted September 1, 2005 hello, what freq does standard tv operate on ? ( standard bbc,itv,channel 4 ) cheers... Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 5, 2005 Share Posted September 5, 2005 It does work, the sound is spot on yet the picture quality is poor. They are also affected by the elements a lot as the sway around !! as smudge says, it will work but not great. how many coat hanger car areials do you see? admitedly not TV but the principle is the same; picture may not be too go though. Quote Link to comment Share on other sites More sharing options...
