minivin Posted August 20, 2005 Share Posted August 20, 2005 I've got issues, however lets talk about the Land Rover I didn't like the ol' Series throttle linkage so I sold that on and brought myself a defender throttle pedal assembly, I've cut a few bits and bent the mounting plate (tread pedal is standard) and got it to follow the contours of a Series foot well. With it in I put the cable in with a split pin loosely and decided to have a squint in the engine pay to see if all was good, the pedal seems to have the same bell crank ratio as the series parts however my throttle positions are as follows on the CAV: nuts and bolts falling off position (at tick-over) lots of black smoke and mopeds over taking you (throttle to the floor) me question be, is it meant to go all the way to the end stop? Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 20, 2005 Share Posted August 20, 2005 Would seem reasonable, sort of why the stops there. Could the clevis pin not be fitted nearer the pivot point? Seems to be slotted for adjustment. Quote Link to comment Share on other sites More sharing options...
minivin Posted August 20, 2005 Author Share Posted August 20, 2005 Just moved the block on the slot and it made minimal difference reducing the ratio on a crank-point and no difference doesn't compute at this moment Quote Link to comment Share on other sites More sharing options...
MarkieB Posted August 20, 2005 Share Posted August 20, 2005 there was me thinking after I'd cleaned my engine it had improved quite nicely. It seems I'll have to pick up the windolene. Natty shade of red, too B) Quote Link to comment Share on other sites More sharing options...
minivin Posted August 20, 2005 Author Share Posted August 20, 2005 I must say the shinny red does take your eyes away from the rest of the crudy engine wonder what I'll do the V8 before I fit it in........ illuminescent green perhaps Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted August 20, 2005 Share Posted August 20, 2005 Yep nice clean engine Cheers Steve Quote Link to comment Share on other sites More sharing options...
