audiman Posted June 12, 2009 Share Posted June 12, 2009 Got home from work yesterday and noticed that the front tyre ns was flat got my compressor out and reinflated tyre ran engine for a couple of minutes as comp runs off cig socket got up this morning checked oil and water levels and washer bottle as going away later today for weekend then checked fuess noticed there is a 15 amp that has popped anyway came to drive it to work will turn over but wont fire a could it be I did not put enough back in battery using compressor last night and battery has not got enough to start engine or could the fuse be the problem? i can still go away as I can use my audi which is main car just smaller boot space any ideas cheers Lee Quote Link to comment Share on other sites More sharing options...
rope runner Posted June 12, 2009 Share Posted June 12, 2009 Hi im guessing this is probably EFI as you havent said . I have had this a couple of times with v8s when they have only been run for a couple of minutes and not reached running temp the prob could be the plugs flooded up .Take them out and give them a good clean and dry out. Quote Link to comment Share on other sites More sharing options...
audiman Posted June 15, 2009 Author Share Posted June 15, 2009 sorry yes its efi replaced fuse and it now starts have now worked out that the 15 amp is the fuel pump fuse which would explain why it would not start but thanks for the advice cheers Lee Quote Link to comment Share on other sites More sharing options...
