foggy3061 Posted June 16, 2009 Share Posted June 16, 2009 I take it that as the 200tdi engine were at one point offered as an upgrade from the 2.5 N/A diesel and 2.5 TD engine, that the wiring loom from either a 2.5 N/A or 2.5 TD can be used or is easily modified to use with a 200TDI? Does anybody know what needs altering, if at all, or if a wiring diagram for the conversion exists? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted June 16, 2009 Share Posted June 16, 2009 I take it that as the 200tdi engine were at one point offered as an upgrade from the 2.5 N/A diesel and 2.5 TD engine, that the wiring loom from either a 2.5 N/A or 2.5 TD can be used or is easily modified to use with a 200TDI?Does anybody know what needs altering, if at all, or if a wiring diagram for the conversion exists? Thanks for your help. It's a simple plug-in job if going from a TD to a Defender spec 200 Tdi. The only addition is the glow plug timer relay and associated wiring - which again is a plug in. I fitted a 200Tdi to my own 110 about 5 / 6 years ago and everything was a straight bolt-in or plug-in swap. See here for details: Land Rover 200 Tdi re-power instructions Matt Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted June 16, 2009 Author Share Posted June 16, 2009 Nice one! Cheers Matt, that's just the info i'm after! Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 16, 2009 Share Posted June 16, 2009 It's a simple plug-in job if going from a TD to a Defender spec 200 Tdi. The only addition is the glow plug timer relay and associated wiring - which again is a plug in. I fitted a 200Tdi to my own 110 about 5 / 6 years ago and everything was a straight bolt-in or plug-in swap. See here for details: Land Rover 200 Tdi re-power instructions Matt Yep - what Matt says. I didn;t bother witht the glow plug timer relay system, i just wired the glow plugs up as the TD was - i don;t need them even on a winter morning, so don;t need the 15 secs of heating i did with the TD. The only other difference is that the engine temp sender unit on the defender 200tdi is at the front near the water pump rather than at the back where it is on the TD - the wire is already hanging there though. Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted June 16, 2009 Author Share Posted June 16, 2009 Excellent, all good info! Cheers reb78. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2009 Share Posted June 16, 2009 that .pdf file is a copy of the retor-fit instructions I put up sometime ago. the only wiring change is for the relay timer controlled glowplugs & thier warning light, the info is within that .pdf file. Quote Link to comment Share on other sites More sharing options...
