Malcyt Posted June 16, 2009 Share Posted June 16, 2009 Hi, Can anyone tell me what size socket I will need to undo the Hub nuts on a 1990 Defender 90.....it the rear axle with Disc brakes. I want t make sure I have the right tools before I start the job of replacing shot wheel bearings. I've looked at the Tech Archive and found some great instructions but no sizes. Thanks Malc Quote Link to comment Share on other sites More sharing options...
white90 Posted June 16, 2009 Share Posted June 16, 2009 52mm for the bearing adjustment/lock nut Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 16, 2009 Share Posted June 16, 2009 Hi, Can anyone tell me what size socket I will need to undo the Hub nuts on a 1990 Defender 90.....it the rear axle with Disc brakes. I want t make sure I have the right tools before I start the job of replacing shot wheel bearings. I've looked at the Tech Archive and found some great instructions but no sizes.Thanks Malc Possibly best to buy a hub nut socket like this to do the job properly http://cgi.ebay.co.uk/Land-Rover-Wheel-Bea...%3A1%7C294%3A50 as the socket needs to be quite deep really. This was just the first one that came up on ebay when i searched. Not really expensive adn will enable you to do it easily. Oh and its 52mm. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2009 Share Posted June 16, 2009 http://shop.difflock.com/land-rover-spanner-plain-p-33.html Quote Link to comment Share on other sites More sharing options...
headhunter Posted June 16, 2009 Share Posted June 16, 2009 Possibly best to buy a hub nut socket like this to do the job properlyhttp://cgi.ebay.co.uk/Land-Rover-Wheel-Bea...%3A1%7C294%3A50 as the socket needs to be quite deep really. This was just the first one that came up on ebay when i searched. Not really expensive adn will enable you to do it easily. Oh and its 52mm. I have one of these from Britpart, distorted on first use, did not undo the nut, complete rubbish and a waste of my time. Ensure you get one that is robust enough to do the job. John Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 16, 2009 Share Posted June 16, 2009 This is he better tool IMHO. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 16, 2009 Share Posted June 16, 2009 This is he better tool IMHO. Are they deep/long enough for the defender? The nuts shouldn;t be so tight on the defender that you need enough force to distort the spanner. Quote Link to comment Share on other sites More sharing options...
cieranc Posted June 16, 2009 Share Posted June 16, 2009 I have one of these from Britpart, distorted on first use, did not undo the nut, complete rubbish and a waste of my time.Ensure you get one that is robust enough to do the job. John The nut shouldn't be that tight that it twists the box spanner! I suspect it's been well over-torqued. I wouldn't spend 18 quid for a chromed socket when a box spanner is more than up to the job. Quote Link to comment Share on other sites More sharing options...
cieranc Posted June 16, 2009 Share Posted June 16, 2009 D'oh! Quote Link to comment Share on other sites More sharing options...
Malcyt Posted June 16, 2009 Author Share Posted June 16, 2009 Thanks all....I'll make sure I get a tool man enough to do the job. Quote Link to comment Share on other sites More sharing options...
