A-Frame Ball Joint Bolts
Hi all,
I'm currently in the process of changing the A-Frame Ball joint.
Problem is while unding the bolts to remove the holder from the arms i has managed to shear off both off them (yes they have been soaking in WD40 for a couple of days)
so can any one tell me the specs on those bolts so i can replace them?
FYI is a 1988 90 if that makes any differance
Cheers
Adam
Can someone post a picture of it - I keep hearing about the A-Frame ball joint, but have no idea what or where it is on the vehicle!
sits on the rear upper curve of the read axle diff casing with the 2 A frame arms going forward at a angle to the chassis mounting.
