wheatfielder Posted June 17, 2009 Share Posted June 17, 2009 Yes, as above- light seems to turn on and off without any human influence. Guess it must be rust at a door switch causing the circuit to earth and so come on? Any other explanations? Cheers again all and thanks. Have got some new door switches and a day off tomorrow so raring to go. (2001 200tdi 90 station wagon.) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 17, 2009 Share Posted June 17, 2009 Most likely the switch I would say, they are poor construction and easily short and turn the light on. Other than that - frayed wire somewhere Les. Quote Link to comment Share on other sites More sharing options...
MJIbex Posted June 17, 2009 Share Posted June 17, 2009 Would agree that a faulty light switch or door pin switch is most likey. However I had had the same issue on my 2006 110. Traced it eventually to the drivers door striker had become loose and could move back and forth, and at any given moment the switch could open the light would come on for 10 minutes and then go off because of the time override circuit. Mark. Quote Link to comment Share on other sites More sharing options...
