bishbosh Posted June 22, 2009 Share Posted June 22, 2009 Morning folks, I am after some specific photos please of the connection between your rock / tree sliders and the tubular outrigger on your 90. From what I can gather from others the box section size often used is shallower in depth than the distance from the vehicle bodywork to the bottom of the outrigger so I want to see how it all goes together before I make some for myself. If you could quote the size of your box section that would help too. Thanks in advance, Bish. Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 22, 2009 Share Posted June 22, 2009 Hi Bish Is it worth fabricating your own. I bought some galvanised rock sliders from Paddocks 3 years ago.. http://www.paddockspares.com/pp/OFF_ROAD/P...Galvanised.html and they've been fine since. £85+VAT They are nice and wide, so they stop a lot of mud being splattered up side of the 90. I would definitely recommend galvanising even if you do decide to make your own. Cheers Steve Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 22, 2009 Author Share Posted June 22, 2009 Definately! Especially after spending a whole two pounds on the tube for the tree sliders from the scrappy!! Besides - the rock sliders you linked to are + VAT and delivery so over £100 and no tree slidery bits either. Quote Link to comment Share on other sites More sharing options...
markyboy Posted June 22, 2009 Share Posted June 22, 2009 Morning folks,I am after some specific photos please of the connection between your rock / tree sliders and the tubular outrigger on your 90. From what I can gather from others the box section size often used is shallower in depth than the distance from the vehicle bodywork to the bottom of the outrigger so I want to see how it all goes together before I make some for myself. If you could quote the size of your box section that would help too. Thanks in advance, Bish. Hi Bish, I can do this tonight when I get home if you still want it. I think my rock sliders are Sh*tpart IIRC. Is it just the rear mounting that you want then? Mark. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 22, 2009 Author Share Posted June 22, 2009 Yes please - particularly interested in where the box section sits relative to the bottom edge of the out rigger and relative to the bodywork of the truck. - i.e. is there a gap between the top of the box and the underside of the sill? don't forget the size of the box section too Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 22, 2009 Share Posted June 22, 2009 Definately! spelling Bish :rolleyes: .. and no tree slidery bits either. They slide along trees just fine I'll have you know ;) Quote Link to comment Share on other sites More sharing options...
markyboy Posted June 22, 2009 Share Posted June 22, 2009 Yes please - particularly interested in where the box section sits relative to the bottom edge of the out rigger and relative to the bodywork of the truck. - i.e. is there a gap between the top of the box and the underside of the sill?don't forget the size of the box section too OK mate, got that. I'll do it tonight when I get home. IIRC, on one side, (N/S) the slider is tight up against the bodywork, bearing in mind the outrigger has been replaced, and on the other side there's approximately a 1/4 inch gap. I'll take some photo's, measure the box section and post them later. Regards, Mark. Quote Link to comment Share on other sites More sharing options...
muddy Posted June 22, 2009 Share Posted June 22, 2009 Quote Link to comment Share on other sites More sharing options...
tommi Posted June 22, 2009 Share Posted June 22, 2009 Quality Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 22, 2009 Author Share Posted June 22, 2009 "Specialist Interest" website Muddy....??????? Quote Link to comment Share on other sites More sharing options...
markyboy Posted June 22, 2009 Share Posted June 22, 2009 Yes please - particularly interested in where the box section sits relative to the bottom edge of the out rigger and relative to the bodywork of the truck. - i.e. is there a gap between the top of the box and the underside of the sill?don't forget the size of the box section too OK Bish, here we go. Firstly, the box section that the sliders are made from measures 100mm x 50mm. Distance from the end of the outrigger tube to the inside face of the slider is approx 75mm. Distance from the outside face of the chassis rail to the inside face of the slider is approx 408mm. Distance from the top edge of the slider to the lower edge of the rear body is approx 8mm (not measured). The tube of the slider which fits inside the outrigger tube is approx 42mm O.D. x 36mm I.D. Here is a photo of the side view. View from below and in front. View from underneath. Hope that gives you what you're looking for, if you need anything else please let me know and I'll do my best to get it for you. HTH. Mark Quote Link to comment Share on other sites More sharing options...
92.9 Posted June 22, 2009 Share Posted June 22, 2009 This may be of some help also: http://www.lro.com/forum/viewtopic.php?p=1...082ca9e5149380f Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 22, 2009 Share Posted June 22, 2009 This any help? (in the CAD archive......) Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 22, 2009 Author Share Posted June 22, 2009 Thanks a lot Mark, really appreciate the effort you went to. Got everything I needed too!! Quote Link to comment Share on other sites More sharing options...
markyboy Posted June 22, 2009 Share Posted June 22, 2009 Thanks a lot Mark, really appreciate the effort you went to. Got everything I needed too!! Glad to be of assistance mate. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 22, 2009 Author Share Posted June 22, 2009 92.9 and Pete, thanks for the links. I had seen the drawing before but as it wasn't done using CAD (shreddies) it doesn't qualify for use I am afraid! What has confused me is friends quoting their box section size as being 70 or 80mm deep which didn't make sense unless the slider sat a fair way below the bodywork, or the tube that slides inside the outrigger protrudes beneath the box which is obviously not ideal. So, looks like 100 x 50 x 3 or 4 I suppose. Thanks all! Quote Link to comment Share on other sites More sharing options...
wobble_hd Posted June 23, 2009 Share Posted June 23, 2009 You could also have a look at this, maybe it is of some help: 90sliders Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 23, 2009 Share Posted June 23, 2009 Bish My DIY sliders can be seen on a previous topic here. They're pretty much the same as markyboy has shown. Made from 100x50x3 box section. Quote Link to comment Share on other sites More sharing options...
mrfish Posted July 10, 2009 Share Posted July 10, 2009 Photo of mine for what it is worth. I'm afraid it's in Zambia at the moment so I can't take photos of how it is mounted. It uses brackets and bolts as opposed to tubes. Quote Link to comment Share on other sites More sharing options...
The Badger Posted July 10, 2009 Share Posted July 10, 2009 Here are mine, I prefer the rock / tree slider type as I use the bar bit as a step to get in. They are galvanised, which I have then painted black. They are from First Four Quote Link to comment Share on other sites More sharing options...
