LandyManLuke Posted March 19, 2006 Share Posted March 19, 2006 Does anyone have the EPC exploded view of this hose, and the part number for it? Mine has a split in it, which makes the snorkle a little redundant. it's a bugger to feel under the heater box to see what's going on. Ta Luke Quote Link to comment Share on other sites More sharing options...
Ajlorton Posted March 19, 2006 Share Posted March 19, 2006 Mine's split also, so I'll be keen to know a) the part number, B) how much the part costs & c) how you fit it. I'm guessing that the heater might need to come out to get down to the wing fixing. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 19, 2006 Author Share Posted March 19, 2006 I've not needed to go there before, but im not sure how much we'd gain by taking the heater out, as it seems to sit on a plate, and the hose goes below this. I'm hoping its not a case of taking the wing off. hopefully EPC will explain it a bit. Luke Quote Link to comment Share on other sites More sharing options...
white90 Posted March 19, 2006 Share Posted March 19, 2006 ESR184 £48 ish item 13 ? Quote Link to comment Share on other sites More sharing options...
JST Posted March 19, 2006 Share Posted March 19, 2006 Can't you just use any bit of pipe as its just going to the snorkel? try one of the snorkel suppliers and see if they will supply you just a bit of pipe, preferably one that does snorkel that dont go straight to the wing grill hence come with pipe extensions (eg Southdown?) well its a pic, now about that resizing........... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 19, 2006 Author Share Posted March 19, 2006 I've got a safari snorkle, so i need that original pipe, or something very close. a reply to my LRO post has shown that at the wing end, that pipe pushes onto part of the grill assembly, so i just need to fork out for a new pipe and hopefully i'll be able to change them over without having to remove the heater or wing. cheers for the price estimate, ouch! Luke Quote Link to comment Share on other sites More sharing options...
Ajlorton Posted March 19, 2006 Share Posted March 19, 2006 £48!!! I'm off to find the gaffer tape. I've just noticed the top hose (9) is also split on mine. I doubt I can afford a replacement one of those either. More silver tape then. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 19, 2006 Author Share Posted March 19, 2006 Don't trust gaffa with my engine, myself. £48 or a potential engine rebuild? no question if you ask me. Luke Quote Link to comment Share on other sites More sharing options...
Ajlorton Posted March 19, 2006 Share Posted March 19, 2006 I should add that I don't intend on using the gaffer fix for preventing water ingress while wading. I'll not be going anywhere near water until it's properly fixed. Unfortunately, I just don't have the cash for anything better and this will prevent the split getting any bigger and dust/dirt getting into the turbo. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 20, 2006 Share Posted March 20, 2006 I should add that I don't intend on using the gaffer fix for preventing water ingress while wading. I'll not be going anywhere near water until it's properly fixed. Unfortunately, I just don't have the cash for anything better and this will prevent the split getting any bigger and dust/dirt getting into the turbo. If you use tank tape and not the cheaper gaffer tape you'll find the tank tape waterproof as well as bomb proof. I eat rat poison mike I can cause trouble in an empty house !! Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 if its just hose though why spend the £50 on the LR part when you could spend a tenenr on a bit of pipe the same diameter that will do the job? Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 go on then TC how did you do it? Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2006 Share Posted March 20, 2006 ESR184 £48 ish item 13 ? Here's the wing intake parts Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 20, 2006 Author Share Posted March 20, 2006 if its just hose though why spend the £50 on the LR part when you could spend a tenenr on a bit of pipe the same diameter that will do the job? So where can i get hose? the same size, with rubber ends to seal to the airbox and wing? Luke Quote Link to comment Share on other sites More sharing options...
JST Posted March 20, 2006 Share Posted March 20, 2006 Luke, air box is jubille clip around the outside of hose to metal part of container, use silicon inside to help the seal if required. the plastic part of the bottom of the side grill will also accept a hose in the same way as the filter. In response to who coudl supply the pipe from my first post: 'try one of the snorkel suppliers and see if they will supply you just a bit of pipe, preferably one that does snorkel that dont go straight to the wing grill hence come with pipe extensions (eg Southdown?)' Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 20, 2006 Author Share Posted March 20, 2006 I'll have a ring around. I wouldnt want to use a plain section of the wire coil type pipe that LR do, can see the ends of that being a bugger to seal. I might try and get some marine wet exhaust pipe, thats available around the right diameter range, and well up to taking chaffing etc, as its a rubber/fabric pipe. Luke Quote Link to comment Share on other sites More sharing options...
LR90 Posted March 21, 2006 Share Posted March 21, 2006 Look at all those joints and vent!! I decided to ditch my orig snorkel and fit a southdown and now have only ONE joint between snorkel top and air box And I found the pipe in question had chaffed through as well (buried under the heater so you can't see it till you remove it). As mine was not going to be refitted I removed the original snorkel and extracted the pipework and placky parts shown in Western's second pic though the hole in the outer wing leaving wing and heater intact and in place. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 24, 2006 Share Posted March 24, 2006 James press the "prt scr" button on the Keyboard then open paint right click and paste then save as JPG file save into image cave then posted here. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted March 24, 2006 Share Posted March 24, 2006 The airbox to wing pipe does delaminate (mine did) and when it does it makes you think you have killed the engine! I use the same pipe to connect my snorkel up to the airbox. Will Quote Link to comment Share on other sites More sharing options...
Ajlorton Posted March 24, 2006 Share Posted March 24, 2006 Just FYI, I went to my local indy LR parts place (Bearmach Swindon) and following a sharp intake of breath following their quote of £48, they offered me 30% off, which brings it down to around £33. Still too steep for me, so I'm just replacing the top gaffer taped one for the time being. £33 for a two-foot length of plastic hose. They're having a giraffe. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted February 14, 2012 Share Posted February 14, 2012 Does anyone know the diameter of this hose - really don't want to fork out £34ex vat for one... Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted February 14, 2012 Share Posted February 14, 2012 OK stupid question: does the southdowns kit come with the airbox to snorkel hose? http://www.southdown4x4.co.uk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=15&category_id=1&option=com_virtuemart&Itemid=1 Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted February 14, 2012 Share Posted February 14, 2012 RTFM - sorry people I am tired : "The flexible hose on these units run directly from the base of the stainless pipe to your Air Filter Assembly eliminates several joints on standard pipe work that can fail, just when you don't need them too!!" Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted February 14, 2012 Share Posted February 14, 2012 please ignore - southdowns snorkel comes with hose... Damn it i'm tired... Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted February 14, 2012 Share Posted February 14, 2012 This is how I did it and the pipe I used http://forums.lr4x4.com/index.php?showtopic=68064&hl=&fromsearch=1 Quote Link to comment Share on other sites More sharing options...
