Tomcat Nev Posted March 20, 2006 Share Posted March 20, 2006 How come the axle is so far forward is that due to the extended radius arms or are the wings is too short ? Neither. Its due to the entire frame being mounted approximately 2 ionches further back than it should be. When i originaly bought the car it was just a chassis with the frame welded on by Bowler (Before he sold the rights to Tomcat) for a bloke who wanted it like that. However, i did not realise that he had done that until much later (and one divorce ) so was a bit miffed as makes fitting panels a complete PITA. The radius arms do increase the wheel base by 25mm to 101" but that is taken up at the back. I had a real problem with the rear suspension at Sidbury - it kept kicking up at the back really high so much so i though at one point i was going over Maybe i need a bit more rebound damping. Time to clean it and then quickly strip the motor and see what is going on as its not a happy teddy bear!! Cheers Nev Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 20, 2006 Share Posted March 20, 2006 Nev, from what I saw of you booting around, it looked to be over-fueling quite a bit.... Nice big puff of black / grey smoke as you launched off the start line. Quote Link to comment Share on other sites More sharing options...
jules Posted March 21, 2006 Share Posted March 21, 2006 Nev, from what I saw of you booting around, it looked to be over-fueling quite a bit.... Nice big puff of black / grey smoke as you launched off the start line. Your only saying that to wined him up. Quote Link to comment Share on other sites More sharing options...
Tomcat Nev Posted March 21, 2006 Share Posted March 21, 2006 Puff of smoke? Black/Grey? Winding me up? The car used 10 litres of oil in the morning and then virtually none in the afternoon So you may have seen oil smoke rather than a fuel puff!!! I also happen to know the air/fuel mixture at all times (me smug?) as i have a wide band lamda sensor which aids in tuning. True i did not race with my lap top in my, er, lap but i did do 95mph (on diamond grips oops) on a private road in Hampshire so know its ok at high rpm/high loads! I just need to lean out the low load/low rpm sites and she will a sh*t kicker. Its all ready better than the Hot Wire system and i have not fine tuned it! Any one good at making non detaching exhausts?????? Cheers Nev Quote Link to comment Share on other sites More sharing options...
