warn 8274 help
davidlandy
I have just managed to source myself an 8274 , got it cheap from a mate.
It needs some work doing on it to fix the the brake - this was welded up!, but I have unwelded and managed to remove it to find no friction material or bearings in it (i take it there are supposed to be bearings in it) - are these parts readily available, and where do they go ? what size bearings are they?
it is also reported to be geared down as it used to be on a recovery truck - but I am unsure which gears would had be changed and how they are different from the standard ones - any ideas how I can tell?
I think that it also needs the bush for the other end of the drum too and the little cover plate - so if anyone has any spares laying about that they want to get rid of for cash then let me know.
thanks all
thats a good sign then Nick - I must admit that all the gears do at first glance to be the same as the stock stuff. But the guy did say that he had to slow it down as it was on a beaver tail recovery truck and was too fast to drag the cars up on the back. So if he did then I wonder how he did slow it?
