forkrentfitter Posted July 1, 2009 Share Posted July 1, 2009 evening all,i am in the process of fitting the 300 tdi out of my discovery into a 90(1992)the rad appears to sit too high,what is the usual solution?is it to cut down the brackets on the front cross member?thanks in advance,chris. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted July 1, 2009 Share Posted July 1, 2009 When I did this, I did exactly that - chopped the tops off the mounts then welded them back on lower down. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 1, 2009 Share Posted July 1, 2009 Cut off 28mm. Make sure the hole in the centre stays in the same plce relative to the crossmember. Les. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted July 1, 2009 Author Share Posted July 1, 2009 Cut off 28mm. Make sure the hole in the centre stays in the same plce relative to the crossmember. Les. excellent les,thankyou. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 2, 2009 Share Posted July 2, 2009 excellent les,thankyou. Les, You should put one of those pics as your avatar, second time in two weeks I've seen them go past Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 3, 2009 Share Posted July 3, 2009 I cut the bottom mounts off the rad surround instead, drilled two holes in the bottom to line up with the holes in the chassis mounts and passed bolts through - worked a treat and no welding Quote Link to comment Share on other sites More sharing options...
