philbert Posted July 3, 2009 Share Posted July 3, 2009 Hi all hope you can help. put my hazards on last night for about 2 mins.switched them off and went to indicate to move off and i have no indicators! coincidence? or has the indicator switch chucked it? Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 3, 2009 Share Posted July 3, 2009 Hi all hope you can help.put my hazards on last night for about 2 mins.switched them off and went to indicate to move off and i have no indicators! coincidence? or has the indicator switch chucked it? No, probably the hazard switch, through which the feed to the flasher unit passes. Quote Link to comment Share on other sites More sharing options...
philbert Posted July 3, 2009 Author Share Posted July 3, 2009 never thought of that! will get a new hazard switch and try that first. thanks Quote Link to comment Share on other sites More sharing options...
outdoor_ian Posted July 3, 2009 Share Posted July 3, 2009 Sounds daft, but flick the hazard switch a few times. Off and on etc... If i've used my hazards and go to use the indicators sometimes they dont work as has happened to you. I just flick the hazard switch a few times and hey presto indicators are back. Its worth a try and could save you £15 which is roughly how much a hazard switch will cost you. Happy flicking Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 3, 2009 Share Posted July 3, 2009 There's a post in the archive detailing the operation of the hazard switch. The indicators and hazards use the same relay, and are both routed through the hazard switch. Often, wiggling the hazard switch will get your indicators back up and running. Quote Link to comment Share on other sites More sharing options...
chrisp Posted July 3, 2009 Share Posted July 3, 2009 There's a post in the archive detailing the operation of the hazard switch.The indicators and hazards use the same relay, and are both routed through the hazard switch. Often, wiggling the hazard switch will get your indicators back up and running. I have odd light problem too- sorry to barge in on thread but do you guys know the answer to this? As of yesterday I have no full beam function if push stalk forwards, but if want to full beam to flash, it will let me if pull back Does any one know what is going on here please? Thanks Chrisp Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 3, 2009 Share Posted July 3, 2009 I have odd light problem too- sorry to barge in on thread but do you guys know the answer to this?As of yesterday I have no full beam function if push stalk forwards, but if want to full beam to flash, it will let me if pull back Does any one know what is going on here please? Thanks Chrisp The main beam (away) is fed from a different place from the flash (towards). You need to trace the blue wire off the flasher switch, back to the off-side-head switch - something loose somewhere, but no fuses in this bit of the system to fail! Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted July 3, 2009 Share Posted July 3, 2009 Philbert: Mine did this, after hazarding no indicators. Turned out to be a bad connection at fusebox to hazards fuse. [My fault as I swapped a glass type to blade type fusebox, to gain axtra fuses and reliability face/palm ] Quote Link to comment Share on other sites More sharing options...
philbert Posted July 3, 2009 Author Share Posted July 3, 2009 well it would appear to be the hazard switch.removed the panel to look at it and the switch fell apart! at least the indicators work now! cheers all Quote Link to comment Share on other sites More sharing options...
