Gren_T Posted July 4, 2009 Share Posted July 4, 2009 Hi can anyone help with the part number for the anti rattle springs and split pins for an early 110 brake caliper made by AP numbers on the caliper are 3247-682C J6C4. I have tried all available @bearmach and the anti rattle springs are far to large. thanks in advance Gren Quote Link to comment Share on other sites More sharing options...
western Posted July 4, 2009 Share Posted July 4, 2009 there are various types of anti-rattle/pad retainer pins/springs RTC6799 pin & coil spring set 606699 a plate type spring My 110 up to 1986 parts book only shows the 606688 for the front brake pads. there's no reason why you can change to the RTC6799 pins/springs. Quote Link to comment Share on other sites More sharing options...
Gren_T Posted July 5, 2009 Author Share Posted July 5, 2009 hi there i've tried the pins and springs but they dont fit in the holes on the caliper. I'll order the 6688 and see if they fit. many thanks for your time Gren Quote Link to comment Share on other sites More sharing options...
western Posted July 5, 2009 Share Posted July 5, 2009 so just clean the pin holes out with a suitable size drill bit or a thin round file, the pins only need to slide in, doesn't matter if they are a bit tight in the hole, a tap from a hammer/punch will set them through OK. Quote Link to comment Share on other sites More sharing options...
