Jimmy Two-Jacks Posted July 5, 2009 Share Posted July 5, 2009 Just thought I would look at getting some either torx or Allan bolts for the door hinges does anyone know the pitch and thread and of course the size of bolts for early 90 hinge bolts? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted July 5, 2009 Share Posted July 5, 2009 I bought the Mudstuff SS bolt kit for my 110, must get the remaining bolts fitted. http://www.mudstuff.co.uk/Stainless_Steel_Bolt_Sets.shtml give Kev a ring, he will advise on the best kit for your truck. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 5, 2009 Share Posted July 5, 2009 Thread should be M8 coarse. Les. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted July 6, 2009 Share Posted July 6, 2009 remove a hinge to bulkhead and a hinge to door bolt and measure the length, they are as Les said M8x1.25, save yourself some money and pop into your local fastners place, always worth buying a new set of captive nuts for the bulkhead, they are really cheap and there will be at least one that you won't take alive! Mike Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted July 6, 2009 Share Posted July 6, 2009 Early 90/110 captive nuts aren't metric. For stainless bolts you'll need Td5> captive nuts, which are metric, and generic Torx [yuk] or allen bolts. Eight genuine captive nuts and c/sunk bolts from somewhere like Seascrew will be half the price of a kit. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 11, 2009 Author Share Posted July 11, 2009 Early 90/110 captive nuts aren't metric. For stainless bolts you'll need Td5> captive nuts, which are metric, and generic Torx [yuk] or allen bolts. Eight genuine captive nuts and c/sunk bolts from somewhere like Seascrew will be half the price of a kit. Thanks, I think I worked the bolts out to be 5/16 unf in the end because my 90s an older one. I will replace them with some m8s though. Thanks again James Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2009 Share Posted July 11, 2009 Yep, 5/16 UNF or M8, did a reply in the part number forum earlier today. don't forget the M8 'J' nuts for the bulkhead pillars Quote Link to comment Share on other sites More sharing options...
JonM Posted July 12, 2009 Share Posted July 12, 2009 How do you insert the J nuts? Blowed if I can see how to get them in there. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 12, 2009 Share Posted July 12, 2009 There's a square hole right above the hole where the bolt passes through. You hook it in the square hole and press it until the nut is inside with the thread behind the round hole. Les. Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2009 Share Posted July 12, 2009 as above Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 12, 2009 Author Share Posted July 12, 2009 as above Careful though its easy to loose the little swines inside the pillar Quote Link to comment Share on other sites More sharing options...
western Posted July 13, 2009 Share Posted July 13, 2009 Careful though its easy to loose the little swines inside the pillar oh dear, don't tell me you lost one a straightened out wire coat hanger & go fishing for the little blighter, got one of mine back that way. Quote Link to comment Share on other sites More sharing options...
