furnivalents Posted July 11, 2009 Share Posted July 11, 2009 Have just found a problem with my 2000 Freelander, the hazard warning lights do not flash ! The indicators are fine however when I put the hazard lights on, the indicator on the dash comes on and stays on but nothing else. The indicator does not flash nor do any of the indicators light up at all. Any ideas what could be wrong ? don`t have a circuit diagram here to see where the hazards work from, assume they are all on the same system as the indicators. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 12, 2009 Share Posted July 12, 2009 Have just found a problem with my 2000 Freelander, the hazard warning lights do not flash ! The indicators are fine however when I put the hazard lights on, the indicator on the dash comes on and stays on but nothing else. The indicator does not flash nor do any of the indicators light up at all. Any ideas what could be wrong ? don`t have a circuit diagram here to see where the hazards work from, assume they are all on the same system as the indicators. 99% likely to be the hazard switch itself. Quote Link to comment Share on other sites More sharing options...
furnivalents Posted July 12, 2009 Author Share Posted July 12, 2009 99% likely to be the hazard switch itself. Thanks, are they a known problem on the Freelander ? Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted July 12, 2009 Share Posted July 12, 2009 Thanks, are they a known problem on the Freelander ? Not that I've heard! Quote Link to comment Share on other sites More sharing options...
furnivalents Posted July 12, 2009 Author Share Posted July 12, 2009 Have ordered a new switch so fingers crossed. Any other ideas what it might be , don`t have a manual or wiring diagram to trace what else may be involved but would think if the indicators are ok then it must be the switch or a relay. Quote Link to comment Share on other sites More sharing options...
