muddy4x4xfar Posted July 13, 2009 Share Posted July 13, 2009 hi . everyones been really helpfull so far thanks. im rebuilding a td5 engine. does anyone have any ideas on how to tighten the crank bolt back to its original torque. i thinks its about 425 its got to be at. theres got to be any easy way of doing it. cheers everyone Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 13, 2009 Share Posted July 13, 2009 A torque multiplier is the proper way, can you rent stuff like that from tool hire places over there? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 14, 2009 Share Posted July 14, 2009 i would imagine the biggest issue is stopping the engine from turning. There will probably be a position on the flywheel that you can use to lock up the crank while tightening the pulley. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 14, 2009 Share Posted July 14, 2009 i would imagine the biggest issue is stopping the engine from turning.There will probably be a position on the flywheel that you can use to lock up the crank while tightening the pulley. While this thread is live, the second cambelt change is due: can anyone tell be the AF size of the bolt which holds the crank pulley on on a 2.5TD? Thanks. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 14, 2009 Share Posted July 14, 2009 While this thread is live, the second cambelt change is due: can anyone tell be the AF size of the bolt which holds the crank pulley on on a 2.5TD? Thanks. Pretty sure its 30mm Quote Link to comment Share on other sites More sharing options...
Reiny Posted July 14, 2009 Share Posted July 14, 2009 Reb78, On the contrary, I'm rather sure that it's 41mm. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 14, 2009 Share Posted July 14, 2009 Reb78,On the contrary, I'm rather sure that it's 41mm. 30mm is for the radius arm nuts - 41mm seems closer! Quote Link to comment Share on other sites More sharing options...
poohbear Posted July 15, 2009 Share Posted July 15, 2009 IRRC - 30mm - 200Tdi crank bolt 41mm - TD crank bolt to pull it up I've just locked the transmission in low 1st and with diff lock on - then pulled the bolt up with a 6' scaff tube over the breaker bar, stand on wings and pull/push/swear until veins pop out of neck D. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 15, 2009 Share Posted July 15, 2009 I stand corrected - was getting my engines confused! Quote Link to comment Share on other sites More sharing options...
