defender dinky Posted July 16, 2009 Share Posted July 16, 2009 hi all, just done transferbox gearbox and engine conversion from 200tdi to my defender 90 td, alternator wiring different, on td got two thick brown wires one small brown wire, 200dti got one thick brown wire one small brown wire and one white wire which has a little black box on it which used to fit to 200tdi alternator, need wiring diagram to swap over, td has plug connector, 200tdi has O ring connectors can anyone help . cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 16, 2009 Share Posted July 16, 2009 Two thick brown wires are the alternator output, which is the one tdi thick wire. there's a good argument for replacing these, especially if your td alternator was 45A and the new one is 65A. worth checking. The thin brown wire is the warning light wire, it should have a yellow trace along it The white wire is the alternator feed. IIRC it has a grey trace along it. If you don't have a rev counter remove it from the W terminal on the back of the alternator. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 16, 2009 Share Posted July 16, 2009 The two-brown-wire systems were used with 65A alternators I believe, at least according to the diagram in my workshop manual. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 27, 2011 Share Posted November 27, 2011 I'm just wiring a TD into a friends IIa and laying new cables from alternator to battery...this alternator has the 3-pin plug (2 large one small), the one small connection is for the charge light I know, but what about the two large spades? Can I use both connections back to battery? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 27, 2011 Share Posted November 27, 2011 Yep, both large spades are the main 'feed' as it were. Run them to the battery, or to the starter solenoid as that saves an otherwise redundant wire run. Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2011 Share Posted November 27, 2011 (edited) typical alternator connections & their variations Edited October 31, 2023 by western Image restored Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 27, 2011 Share Posted November 27, 2011 Thanks guys, I'll run both as feeds I think. One question, the plug will only cope with wires up to about Ø6mm, which is 70Amp according to VWP. Unfortunatly the label has worn off the alternator so I cant be certain what rating it is. To the best of my knowledge, and I've known the engine for a few years, its an original spec TD alternator. It seems to say 14V 23/55A on it, would that be right? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 28, 2011 Share Posted November 28, 2011 Standard TD alternators are 45 amp, standard disco is 65 amp. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 28, 2011 Share Posted November 28, 2011 Thanks! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 4, 2011 Share Posted December 4, 2011 Well its in anyway...2 70amp cables run from two large spades in the plug straight back to battery, just requires a battery and the terminals fitting to it now! Quote Link to comment Share on other sites More sharing options...
94defender90 Posted October 31, 2023 Share Posted October 31, 2023 I See this is a very old forum, is anyone still here , i have a warning light issue Quote Link to comment Share on other sites More sharing options...
western Posted October 31, 2023 Share Posted October 31, 2023 If charge red light 9n when engine is running or off, the alternator has a internal fault. Quote Link to comment Share on other sites More sharing options...
