Hybrid_From_Hell Posted April 3, 2006 Share Posted April 3, 2006 Humpfh Bigger book then show-orf ? Nige Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted April 3, 2006 Share Posted April 3, 2006 Nige, Want some more ……….here is all the M14 & M16 Part number ……… spanner size……….Size n pitch …………temp on/off 50172 22 M14 x 1.5 87-82 50042 24 M14 x 1.5 90-85/98-93 50041 22 M14 x 1.5 95-90 50173 22 M14 x 1.5 100-95 50040 22 M14 x 1.5 103-98 50481 21 M16 x 1.5 50 OFF N.C.C. 50475 17 M16 x 1.5 60 OFF N.C.C. 50430 17 M16 x 1.5 85 ON 50320 27 M16 x 1.5 85-80 50420 21 M16 x 1.5 85-80 50432 21 M16 x 1.5 85-80 50476 17 M16 x 1.5 85-80 N.C.C. 50300 27 M16 x 1.5 87-80 50317 22 M16 x 1.5 87-82 50321 22 M16 x 1.5 88-79 50310 22 M16 x 1.5 88-86 50301 22 M16 x 1.5 90-83 50474 19 M16 x 1.5 90-83 N.C.C. 50461 21 M16 x 1.5 90-85 50421 21 M16 x 1.5 90-85 50470 17 M16 x 1.5 90-85 N.C.C. 50390 17 M16 x 1.5 90-85 N.C.C. 50316 22 M16 x 1.5 92-82 50330 22 M16 x 1.5 92-82 50453 24 M16 x 1.5 92-85 50315 22 M16 x 1.5 92-87 50341 24 M16 x 1.5 92-87 50342 24 M16 x 1.5 92-87 50371 27 M16 x 1.5 92-87 50373 24 M16 x 1.5 92-87 50450 21 M16 x 1.5 92-87 50340 29 M16 x 1.5 93-86 50374 24 M16 x 1.5 93-88 50479 17 M16 x 1.5 93-88 N.C.C. 50332 22 M16 x 1.5 95-85 50477 17 M16 x 1.5 95-88 N.C.C. 50455 22 M16 x 1.5 95-90 50454 22 M16 x 1.5 95-90 50380 17 M16 x 1.5 97-92 N.C.C. 50478 17 M16 x 1.5 98-91 N.C.C. 50375 24 M16 x 1.5 98-93 50472 17 M16 x 1.5 98-93 N.C.C. 50473 17 M16 x 1.5 98-95 N.C.C. 50431 17 M16 x 1.5 100-95 50331 22 M16 x 1.5 102-97 Ian Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 3, 2006 Share Posted April 3, 2006 Ian, I think you need to get out more Nige Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 4, 2006 Author Share Posted April 4, 2006 Strewth, I got a headache now! Think I'll put the metal fan back on. Anyway - I suppose SNB724 92-87 is abot the right temp range. There are a few that are the same values, so what's the difference between them? Les. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 4, 2006 Share Posted April 4, 2006 shape. Some have "Open Blades" for connections, some have a sheild, etc etc, but basically the same with minor changes. The ones I posted up I know the cars they are fitted to ie Mr Scrappy, Ian are easier new from a Motor factor I guess. Happy asprininining Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 4, 2006 Share Posted April 4, 2006 Les, OK SNB 724 is on the following cars : Fiat 127 900C 127 1050 1271050 sport 127 1300 diesel 128 110 sport coupe 128 1300 131 1300 mirafiori 131 1600 supermitiorfifirori 131 2000 racing 131 2000 super f mirrafioitrertioririoiri 238 SEAT Ritmo 65, 75 124, 1430 D Especiale 124 1600 D 127 900 128 1200, 1430, 1600, 1600E 131 1800 diesel CLX 131 2000 CLX 132 1800 CLX Off yer go, you picked these common easy to find in scrappy cars Nige Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted April 4, 2006 Share Posted April 4, 2006 Les, Nige is spot on ……………. If you decide to go new ……… then the quote the 50xxx number and the factor should be able to show you a picture in the intermotor catalogue ……… The same temp values means differences in applications……… some with blades, some with pins, and others prewired to a plug. Usually the blades are cheapest at about £8 to £10 each. Some of the prewired units are £30+ Ian Quote Link to comment Share on other sites More sharing options...
