Pete Boy
Volvo c303 disc brakes?
Hi there,
Im after a disc brake conversion kit for my C303 axles currently attached to a series 2a.The problem is portal tek used to do them, but are no longer listed on there website.....
Any advice,ideas, or other makes of kit would be helpfull as i really need to get those drums off!!!!!!!
Thanks pete :)
Share this post
Link to post
Drop Jez, (dollythelw) a PM on here. The House of Flying Spanners (HOFS) will be able to help you out.
Share this post
Link to post
Thanks,will do.Been on the "to do" list for a while.
Cheers
Share this post
Link to post
I have the portaltek disc conversion. The actual brake set up is laughably simple, Wilwood rotors and calipers mounted on a very simple bracket. The key is in the stub axle assembly they build to allow the disc set up to work. I'm reasonably sure that they still do the aftermarket stub axles even if they have stopped doing the rest of the kit for some reason. In any event, as per above, check with Jez.
Share this post
Link to post
Does anyone know if OMT offroad still make their disk brake kits?
I've tried emailing them but get no replies.Failing that do HOFS make their own kit?
Cheers Eric
Share this post
Link to post
HOFS don't make their own kits :-(
RPR is correct... the kit comprises of off-the-shelf willwood calipers and disks. The stub axle is the important bit. But its taken us nearly 2 years to get ours from Portal-tek! As far as I'm aware there isn't anybody else who makes them... anybody any good at reverse engineering ;)
Dan
Share this post
Link to post
We are now thinking about making our own conversion for two sets of axles. Any reason not to run RRC/Disco disks and calipers?
In Sweden the equivalent ov DVLA rules are such that as long as we retain the brakes and suspension setup an axle swap is not a large modification.
Tobias
Share this post
Link to post
Tobias
If a kit that used standard LR parts could be cobbled together then that would be a good step forward!
I'll be watching with interest ;)
Share this post
Link to post
Someone posted the following pics in the Land Rover forum on pirate, but gave no details as to who makes them.
Share this post
Link to post
Only that they don't easily fit.
The Portal-Tek kit was about the best answer I've seen to the question (I run the kit and it's excellent), but casting new stub axles was obviously a big step and made a lot of other things much easier. The upside is the discs & calipers were off-the-shelf Wilwood parts which is tricky to do DIY - you can easily end up having to machine your own discs to fit.
We looked at all sorts of ideas before the Portal Tek stuff, there's a few decent ways of doing it (some of the Finns do a pretty effective conversion with Toyota bits) but there are also some total engineering abortions out there which are very scary. The Straightforward Supplies setup I saw falls firmly into that category, we nearly died just from laughing.
Share this post
Link to post
Dan
Dan
Have you got some pictures of the stub axle to start with?
If so i might know a man that can!
If he says he can would obviously need a stub for him to copy and what sort of quantities and price to aim for?
Cheers
Tony
Share this post
Link to post
Hi Tony,
The stub/hub is a cast assembly with various bits of machining done to make it shiny... but its a big old lump.
From what we've heard it should be near on impossible to break the items we have, unless your name is Jezz :lol: , so I don't think we'll be needing replacements for a while.
TBH we've waited so long for our bits I don't really want to let them out of my sight at the mo. But if there was a market and somebody had the time and inclination to make something similar I'm sure we'd be able to work something out.
D
Share this post
Link to post
Hi Tony,
D
Hi Dan
Jezz will probably break them.
I didnt know if there was a demand for these for people who just wanted the stub, and then sorced the calipers ect themselves.
I know a tool maker /engineer /CNC wizzkid who loves a challenge, so if there was a market place for them , im sure he would have the inclination to see what could be done!
If you have got a few pictures of them, i could show him to whet his appetite that would be good!
Cheers
Tony
Share this post
Link to post
Thanks for all the replies and pics,
I know the Malaysians convert their volvo portaled comp trucks to discs but haven't found any pics or info on how they do it,I will keep searching.
Has anyone been able to contact OMT offroad recently?
If someone can make some stubs I would be interested in a set.
Eric
Share this post
Link to post
Tony
Any updates on this?
Share this post
Link to post
Cheers Eric
OMT was sold to xtreme-offroad.de send a mail to Ralf they have them in stock with differant wheel stud patten's!
Share this post
Link to post
I wouldn't touch anything SFS made, I saw one of their disc conversions and it was so scary it wasn't funny.
Share this post
Link to post
I did. No reply yet 1 week after.
Share this post
Link to post
I sent them an email also and got a response 1 week later. The disc brake conversion is if I remember correctly 2500Euro ($3,322USD) and comes with a Toyota bolt pattern. Of course that did not include shipping from Germany. I sent them a reply asking if the Toyota bolt circle was the only option and have not received a response. This kit is not offered on their web site from what I could see. The OMT web site is still up. I called the former owner, that's how I found out of the sale of the business.
Share this post
Link to post
Hi all, I've been on the phone to Ralf's team and bent a few ear's! Aike has said he wil lsend me an email with more info about conversion's, what's options they have too! I'll forward to who ever want's this.
Share this post
Link to post
