big ives Posted July 31, 2009 Share Posted July 31, 2009 hello did a search but found nowt clear only had the landy a few days, out last night in the dark again same as the disco 1 head lights not very bright 2004 td5 how can i get more light? can i put in higher watt bulbs? or HID units? many thanks Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted July 31, 2009 Share Posted July 31, 2009 Inspect Lamp connections for burning as well as all lamp earth points. Quote Link to comment Share on other sites More sharing options...
tuko Posted July 31, 2009 Share Posted July 31, 2009 I don't remember which circuit has a relay, but if you can check the wiring diagram then I would suggest to add another relay to the circuit without. +30% and +50% bulbs are better than the standard bulbs but try to stay away from colored bulbs as they do steal lumen. Higher watt bulbs are illegal and not worth the coins when the above bulbs work just as good or even better. Todd. Quote Link to comment Share on other sites More sharing options...
d1scv Posted August 1, 2009 Share Posted August 1, 2009 hellodid a search but found nowt clear only had the landy a few days, out last night in the dark again same as the disco 1 head lights not very bright 2004 td5 how can i get more light? can i put in higher watt bulbs? or HID units? many thanks Assuming this is a face lift- go careful on upping the wattage. Headlight lens is plastic. Quote Link to comment Share on other sites More sharing options...
Fern Posted August 1, 2009 Share Posted August 1, 2009 Higher watts - evil. They are not permitted on public roads, as said on Osram +80% package, for example. Philips Premium +30% will light as much as Philips Extra, but the price is significantly less. Don't buy bulbs with xenon effect or any other colored bulbs. But Philips Night Guide is ok as i know. Quote Link to comment Share on other sites More sharing options...
big ives Posted August 2, 2009 Author Share Posted August 2, 2009 Higher watts - evil. They are not permitted on public roads, as said on Osram +80% package, for example. Philips Premium +30% will light as much as Philips Extra, but the price is significantly less. Don't buy bulbs with xenon effect or any other colored bulbs. But Philips Night Guide is ok as i know. many thanks everyone for the information i see its just not as simple as bunging in a few higher wattage bulbs Quote Link to comment Share on other sites More sharing options...
