Grant. Posted August 3, 2009 Share Posted August 3, 2009 Hi all, Have a 110 TD5 with a winch and heavy duty bumper fitted Have a 2 inch lift all round with Britpart heavy duty springs, but I get the impression these have started to lose there lift, shall we say. Can anyone suggest a set of good springs that will give about 2-3 inch lift on a td5 110 for the front and rear with all the weight of a fully laden 110? (roof rack, tools etc) Dont mind paying for quality as long as it doesnt start to feel low at the front again! Thanks Grant Quote Link to comment Share on other sites More sharing options...
Marco Posted August 3, 2009 Share Posted August 3, 2009 I do have Old Man Emu 754 springs at the back and they are fine. Much more expensive but probably a better choice. Do consider to replace mine with 755 as 754 is a bit to stiff for my 130 (light load stationwagon). Cheers Marco Quote Link to comment Share on other sites More sharing options...
Grant. Posted August 3, 2009 Author Share Posted August 3, 2009 Hi Marco, What lift do your springs give? Does anyone know what old man emu springs I would need to gain a 2/3 inch lift? Land rover has a winch, roof rack etc etc I also use it for towing 3.5 ton trailers Thanks Grant Quote Link to comment Share on other sites More sharing options...
western Posted August 3, 2009 Share Posted August 3, 2009 Grant, you've seen photo's of my 110 on here, it has OME springs all round, my fronts are 751's & rears are 754's [iIRC] they give me a lift of about 1.5 to 2 inches. Quote Link to comment Share on other sites More sharing options...
Grant. Posted August 3, 2009 Author Share Posted August 3, 2009 Grant, you've seen photo's of my 110 on here, it has OME springs all round, my fronts are 751's & rears are 754's [iIRC] they give me a lift of about 1.5 to 2 inches. Thanks Ralph, So what old man emu springs would I need for a 2.5-3 inch lift? Thanks Grant Quote Link to comment Share on other sites More sharing options...
western Posted August 3, 2009 Share Posted August 3, 2009 have a look on here http://members.shaw.ca/jbarge/springinfo.html#OME just done some measuring, on the front the gap between axle bump stop plate & rubber bump stop lower face is slightly over 4 inches & on the rear is virtually bang one 5 inches, may be worth comparing those measurements to your vehicles existing measurements, that should give you a fair idea if the 751/754 set up will work for you. Quote Link to comment Share on other sites More sharing options...
Mack Posted August 3, 2009 Share Posted August 3, 2009 Hi all,Have a 110 TD5 with a winch and heavy duty bumper fitted Have a 2 inch lift all round with Britpart heavy duty springs, but I get the impression these have started to lose there lift, shall we say. Can anyone suggest a set of good springs that will give about 2-3 inch lift on a td5 110 for the front and rear with all the weight of a fully laden 110? (roof rack, tools etc) Dont mind paying for quality as long as it doesnt start to feel low at the front again! Thanks Grant I just fitted on my 110" Puma, OME751+LLAMA 4x4 3/4" coil spacer in front and 755 on the back. Also adjustable long travel Rancho shoxs. At the end I got 2.5" lift. Very good setup. M Quote Link to comment Share on other sites More sharing options...
