Anderzander
Look what I brought home last night ..
This is a Fairey - perhaps yours was the Toro one ?
Which is a lot better, but has had a problem of parts being unavailable. I say ‘had’ because I read an ad on eBay tonight for one and they are rebuilt units to order ? 🤷‍♂️
I was looking at a Roamerdrive - but this is in decent known condition and at a fair price.
Share this post
Link to post
Hmm, just been having a goggle to see ,  and nothing rings a bell,.......  maybe it was just the FW hubs that were from Brazil but I certainly thought the OD was as well..
Anyway looks like you have a nice unit, ...look forward to seeing the installation:)
Share this post
Link to post
The splines look good on that clutch sleeve.  If the main shaft’s corresponding splines are as good, you’ve been very lucky!
Share this post
Link to post
Someone is rebuilding a late 2a gearbox for me - I’ve a few pictures:
‘Stored under the bench condition’
Late suffix with the larger layshaft - which can’t hurt with the tdi in it.
Stripped to see what’s what...
To replace:
Primary Pinion, 1st gear pair, reverse shaft, 3rd gear pair, intermediate shaft for transfer box .... and on closer inspection, 2nd gear pair 😂
I love a bit of NOS goodness
Cases cleaned
Just waiting painted covers and shift mechanism
  • Like 2
Share this post
Link to post
A nice clean gearbox build is one of the most satisfying workshop jobs. Looks great, will the OD be ready to go with?
Share this post
Link to post
It will be - biggest challenge I have is that by the time I’m ready to fit it all I won’t have access to a workshop with enough width to use the engine crane .... my outside space is pretty rough. So I’m exploring if I can get bigger wheels on it.
Share this post
Link to post
...... or some second hand plywood as a temporary surface, might be easier
  • Like 1
Share this post
Link to post
That's how I do it. I'll lend you the a-frame if you like; the legs detach for easy shipping. Just add an electric winch, chain hoist, tackle blocks or whatever you've got.
Edit: just realised the gearbox pics are an old post! Did you get it sorted?
Edited by lo-fi
Share this post
Link to post
That’s an interesting set up - I assume you lower it to the ground and then pull it out from underneath ?
I haven’t put the gearbox in yet - still collecting parts and getting things ready to do a few things at once.
The aspiration is to do the gearbox, steering, and 11” brakes at the same time....
Share this post
Link to post
its not leaking yet ???
(sorry, couldn't resist :ph34r:)
  • Haha 2
Share this post
Link to post
Yeah. Though to be honest, once you've got it free in a controlled fashion and supported on some blocks it's an easy two man lift with a scaffold bar across the cab and a couple of straps down to the gearbox.
Share this post
Link to post
Great pic's , particularly the black and white , a grey Fergie trundling off down the road with a sheep dog running along behind could only add to it :) .
thanks for posting
Steve b
Share this post
Link to post
