Anderzander
Look what I brought home last night ..
I see what you did there !
They came in two flavours 3.9 and 4.3 - and mine are the 3.9 ...
  • Like 1
Share this post
Link to post
They are excellent - they are made by Carl Radford - I’ve bought his bumper, bulkhead outrigger, bell housing crossmember, gearbox crossmember, and tear crossmember.
I’d definitely recommend his stuff.
Share this post
Link to post
Those repair parts are very neat , I've saved Radfords to my favourites , thanks . Their bulkhead's are nice too by the look of it .
Just off at a slight tangent , how much would a 1600 engine go for ?
Nice work
Steve b
Share this post
Link to post
Unfortunately I think he’s just stopped doing the bulkheads ..
I haven’t seen a running 1600 for sale for ages - they seem to be silly money though. People in the series 1 club are saying that parts and machining to rebuild one is coming in at £4K 😳
The later 2 litre engines, running, seem to be around for £1500 -£2000 - and they can be ‘dressed’ to look like a 1600.
The 200tdi gives 40mpg in an 80” though - that swings it for me.
Share this post
Link to post
Yeah I'm hoping for similar mpg with mine once its done, was getting that with my last S2a 200tdi :D
Share this post
Link to post
Lovely work, it's nice to make an old chassis good.
Well done
  • Thanks 1
Share this post
Link to post
A photo from the painter with the chassis in etch....
...and now back from paint:
Following the suggestion by @Maverik tubes have been let into the middle crossmember in order to Retro fit lap belts. They’re spaced to line up with the gaps between the front seats.
Later series engine mounts fitted - I tortured myself over these, and would perhaps have the, a bit different if I did it again ... I got lost in small details and
Rebuilt dumb irons, new bellhousimg crossmember, and replacement bulkhead outrigger.
Beautiful new rear crossmember !
Onwards and upwards now hopefully - I’ve a new set of springs so it should be rolling before long 😊
  • Like 3
Share this post
Link to post
It’s rolling !
Still struggling to find tubless rims ... but, with help, it’s coming together 😊
Series 2 master cylinder so I can run the 3/16 pipework - Series 1 cylinders (wheel and master cylinder) are a fortune. Mine had standard S1 1/4in system all the way down to the union to the flexible pipe. An adaptor has been made up by welding a 7/16  union to a 3/8 union to take the 1/4in copper pipe to a 3/16 flexible and has S2 cylinders - it’s S2 all the way through now.
S1 springs are only made by a couple of companies, both to order - £600 for a set 😱
Early 2a bellhousing takes a 1951 gearbox to a 1992 engine 😊😀   Thank you Land Rover !
Picture doesn’t show it - but plenty more space between the crank pulley and the axle than there is the bump stop.
Share this post
Link to post
Getting lots of help Soren from a friend of a friend who restores Series 2’s - I can’t claim all the accolades 😊😀
Share this post
Link to post
23 minutes ago, landroversforever said:
That's looking stunning Stephen :wub:
I’m so excited - I spent a fair chunk of the morning just staring at it 💕
  • Like 1
Share this post
Link to post
I thought they looked like Jones' work. I'm soon going to fit a full set to the 109 S3 TC that I put onto a new galv. chassis last year.
I originally sourced through BM but they were over 3 times stiffer than the OE spec, so were returned .
The new Jones springs tested to spec on my test rig so should go on fine .
A friend has just sent his original 2A FC springs to Jones to be refurbed
cheers
Steve b
Share this post
Link to post
I did wonder about the refurbed route - and I asked them for the pro’s and cons of both for my 80  - they said that because of the thin steel they are made from - it doesn’t re harden very well and they can’t get the same result as a new spring.
Share this post
Link to post
I may have to slow down with it a bit while I save some more money - I need to buy quite a few things still for it yet.
The list includes a tank, have the radiator recored, the bodywork needs some ally welding, I want the galv soda blasting and some decent paint put on - I’m still looking for tubeless wheels for it.
I also want some small bits that seem to come with big prices:  the series type expansion tank and bracket, I want a proper s1 horn dip switch (and they are a frightening price), an ignition switch.
After that it’s seats, tilt, and I’m going to fit a diesel air heater.
They’re not cheap these things 😊
Share this post
Link to post
