stop n tail light
could be either blown flaments in each bulb or blow fuses or a busted brake light switch or a wire connection broken or disconnected.
brake light switch is on the top rear of the brake servo/brake master cylinder assembly.
^^^ wot Western said, plus check the bullet connectors behind the covers at the back of the load compartment, they corrode on occasion.
