frrfrr Posted August 14, 2009 Share Posted August 14, 2009 hi there , i have a early 90 and was wondering if any one has upgraded the front bulbs , looking for a bit more light up front . not looking for illegal fancy stuff , but bulbs that are fine with the autorities . has any one changed theres ? was there much difference ? cheers fraser Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 14, 2009 Share Posted August 14, 2009 hi there , i have a early 90 and was wondering if any one has upgraded the front bulbs , looking for a bit more light up front . not looking for illegal fancy stuff , but bulbs that are fine with the autorities . has any one changed theres ? was there much difference ? cheers fraser "Da law" says you can't have a higher POWER bulb (more W's) the the manufacturer fits. What you can so (and I am about to do, and many others no doubt already have done) is to upgrade to +60% or +90% "Xenon" bulbs, which give more light than standard, but at the same wattage. More modern headlamp reflectors can also help, and all this assumes your not talking about sealed beam units Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2009 Share Posted August 14, 2009 the Crystal lense headlights with better output bulbs should improve things [bulbs with +60% or similar but are still 55w dip & 65w main beam] Quote Link to comment Share on other sites More sharing options...
q-rover Posted August 14, 2009 Share Posted August 14, 2009 If you do go for better bulbs get ones with clear glass, as any coating invariably acts as a filter and reduces light output. I have these and am very happy with them. They give a very white light compared to standard halogen bulbs. You could also rewire the wiring using a relay and better wire directly connected to the battery. Quote Link to comment Share on other sites More sharing options...
frrfrr Posted August 14, 2009 Author Share Posted August 14, 2009 hi , cheers for the replies looking for simple plug and play types , will be using the standard lenses / wiring . just need a bit more light than thats on the standard ones the now . cheers fraser Quote Link to comment Share on other sites More sharing options...
hobson Posted August 15, 2009 Share Posted August 15, 2009 I've just got the +90 ones from Autobulbs direct, they're definitely brighter than the +50's that were in (which turned out to be fine and are now spares!) they make a big difference... Quote Link to comment Share on other sites More sharing options...
