2.5 n/a fuse box
... and an exerpt from the wiring diagram
1 and 2 are dip beam, 3 is the fog light, 4 and 5 are main beam, 6 and 7 are side lights, 8 is the heater blower motor, 9 and 10 are the ignition switched accessories (instruments,etc.), 11 and 12 are the always-on accessories (cabin light, cigar lighter).
Hi...there seems to be slight inconsistent with Fuse Labeling,
This is from my LR90 yr 1989
This is from a LR110 yr 1989
The 3rd row on the left with 12A got a missing reverse light symbol.
I'm about to replace the reverse light with a spotlight with H3, 35W bulb. So I'm concern that if the fuse amp rating is sufficient. Based on circuit diagram the reverse light is sharing fuse with wiper motor which is correct as indicated on the 110 fuse label. But for my LR90, seems to be missing the symbol. :unsure:
