will_warne Posted March 29, 2006 Share Posted March 29, 2006 I was wondering if anyone sells a skin for pushbutton type defender door. Most of it would be easy to do but the recess arround the handle would be a little trickier... If not, its time to look out for some new doors this weekend Quote Link to comment Share on other sites More sharing options...
Countax Posted March 29, 2006 Share Posted March 29, 2006 I was wondering if anyone sells a skin for pushbutton type defender door. Most of it would be easy to do but the recess arround the handle would be a little trickier...If not, its time to look out for some new doors this weekend will, No idea how easy it is, but i have a new N/S skin if you are interested. I managed to source a new genuine door so its now surplus to rqmnts. no reasonable offer refused and i could bring it to Old Sod. Nigel Quote Link to comment Share on other sites More sharing options...
siggy Posted March 29, 2006 Share Posted March 29, 2006 I had my previous lift handle doors reskinned so it should be possible to get push button.... try here or try Avenue Panels 01933 313945 (01933 37251 cash and carry) very old numbers Park road rushden northants nn10 0rw Quote Link to comment Share on other sites More sharing options...
siggy Posted March 29, 2006 Share Posted March 29, 2006 Ignore above address new address is here Quote Link to comment Share on other sites More sharing options...
siggy Posted March 29, 2006 Share Posted March 29, 2006 And door skins are just folded over the steel frame and edges flattened watch chap do mine 15 minute job Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 29, 2006 Share Posted March 29, 2006 If not, its time to look out for some new doors this weekend if u're down will, will u have a box in the back of your motor? Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted March 29, 2006 Share Posted March 29, 2006 need another coke Tonk? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 29, 2006 Share Posted March 29, 2006 I know one person who did it on an old vehicle and it looked sort of OK, but mostly it is a waste of time as the first bit to go on Defender doors is almost always the frame around the bottom front corner, so you end up with a hinge bolted to a mixture of rust and fresh air. Unless of course you smite the door on a tree in which case re skinning might be required Quote Link to comment Share on other sites More sharing options...
will_warne Posted March 29, 2006 Author Share Posted March 29, 2006 OK, the plan is to modify the frame slightly anyway (cut the excess weight) so the corrosion isn't a problem. My doors are just about OK, they do need some attention, though. One of the doors has had contact with several trees anyway. Tonks, I'm hopefully going to drop said box off to Ash before Saturday. I'm going to give him a call later. Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 29, 2006 Share Posted March 29, 2006 Yes - paddocks do the skins £55 + vat each. Why would the recessed bit be a problem? It comes already pressed into the panels. Its do-able with a hammer and dolly, but is alot easier with a proper door skinning tool, available from Frosts etc. Alternately I'm sure Ripley is more than capable of doing it for you! Jon Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted March 29, 2006 Share Posted March 29, 2006 He wont have time to do it Jon, he will be too busy looking for those "pestkie rabbits" at Sodbury! Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted March 30, 2006 Share Posted March 30, 2006 Just done my Rangie 2 door skins recently. Crimp tool is good but you still get crimp marks on the folded (inner) tab, if you want a neat finish go over the tab with a copper dolly or a piece of soft wood or wood wrapped with some old leather to tidy it up. I would recommend lining the edge of the panel with non metallic gutter tape or some thin rubber strip to keep the alloy galvanically isolated from the steel frame, you don't need to be too precise, just trim off the excess tape with a Stanley knife before you paint. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 30, 2006 Share Posted March 30, 2006 Will, If you want to save weight that much, change them for proper two part doors...all that glass and trim weighs you know ! nothing to get in the way of the punch card either ! Oh..... And get and use the thing and stop fuppin' about Quote Link to comment Share on other sites More sharing options...
simonr Posted March 30, 2006 Share Posted March 30, 2006 Will, it's not too difficult. Most of the ones supplied have the lip around the outside partially folded so you only have to beat it round over the frame. One bit of advice however - get some thick insulating tape and use it to electrically isolate the skin from the frame. a lot of the corrosion in the both the frame and skin are electrolytic in origin. The insulation stops most of this dead! Si Quote Link to comment Share on other sites More sharing options...
will_warne Posted March 30, 2006 Author Share Posted March 30, 2006 Will, it's not too difficult.Most of the ones supplied have the lip around the outside partially folded so you only have to beat it round over the frame. One bit of advice however - get some thick insulating tape and use it to electrically isolate the skin from the frame. a lot of the corrosion in the both the frame and skin are electrolytic in origin. The insulation stops most of this dead! Si Thanks Si, I was thinking about using RTV sealant to act as an insuator, that way it won't come loose and will also help stick the skin in place while I'm beating the lip down. I'm going to do a lot of work to the frames too to take the weight down and to get rid of some of the water/mud traps. Les, I know what you mean. I've got a few things I want to do and then I'm going to enjoy the truck for a while. I'm hoping to have it all done by mid to late summer but I'll just have to see... Quote Link to comment Share on other sites More sharing options...
minivin Posted March 30, 2006 Share Posted March 30, 2006 If your ging to all this trouble, and as noted about the two-piece door route, wouldn't it be worth looking at possibly getting a pair of frames made in alloy, thereby solving the issues and weight?. Would mean the nasty Series style locks if you go for the old-two-piece style but hay hoo! Quote Link to comment Share on other sites More sharing options...
freeagent Posted March 30, 2006 Share Posted March 30, 2006 if new skins are £55 each, then i'd go for the two piece door option, as new door bottoms from Craddocks are less than that, and at least you could mix and match, use the fancy ally door tops that rocky mountain sell, or leave the door tops off for events, the bottom half of a two piece door could be stregthened fairly easily aswell.... Quote Link to comment Share on other sites More sharing options...
will_warne Posted March 31, 2006 Author Share Posted March 31, 2006 No, I don't want two peice doors as, when the top half's in place you can't really open a window and, when its off, you have to store it somewhere. I've played arround with 2 peice doors before and I've never really been a fan. Quote Link to comment Share on other sites More sharing options...
ripley Posted April 1, 2006 Share Posted April 1, 2006 No, I don't want two peice doors as, when the top half's in place you can't really open a window and, when its off, you have to store it somewhere. I've played arround with 2 peice doors before and I've never really been a fan. I wouldnt use a skinning tool, just good old hammer & dolly , Geniune skins on defenders are'nt the best ones in the world to do, but easy enough, We normally just fit doors now, because insurance companys dont want to pay the labour to fit them, even though it still works out cheaper I would recommend Etch the bare metal then PUR Sealer between the skin & Frame, if you use RTV, you will get silicones in the paint Regards Graham Quote Link to comment Share on other sites More sharing options...
Tom P Posted April 1, 2006 Share Posted April 1, 2006 To keep the aluminium skins from the steel frames can you get the frames powder coated, or doesn’t that work? Tom Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 3, 2006 Author Share Posted April 3, 2006 Cheers Graham, when all the bodywork's done the truck'll need a paint job so I'll be in touch soon. Quote Link to comment Share on other sites More sharing options...
