Sedimenter location.
kingdong2
Hi guys
i was looking under the disco i have just recently bought and came across the sedimenter thought it was in a great place being its a 4x4 vehicle lol anyway got thinking is it possible to do away with the sedimenter and just change the fuel filter more often as it would make servicing alot more easier.
graham
______________________
1962 2a swb 200 tdi.
1997 disco1 300 tdi.
i bought a sedimentor which fits a jcb3cx from ebay about 10 quid it has a gauze filter inside it ive got the pipe and couplings just havent got round to doing it yet all i was going to do with the old one was bypass it using some pipe etc,chris.
Most people only clean the sedimentors out every 10 years + if at all until they cause a problem.
It only takes half an hour to do the job. Chances are you will never need to do it again once it's done.
Definitely stops water getting any further, just drain it now and again. Lot cheaper than a rusty injector pump.
Wot Mr NDFI said, and I meant to describe that it was an add-on to, not a replacement for, the filter.
