Quagmire Posted August 28, 2009 Share Posted August 28, 2009 Right, So last night i was coming round a roundabout - luckiliy quite slowly. As i approached my exit and started to take off the lock it appeared that the steering lock came on- i really didnt didnt have time to analyse what exactly happened, as i was pooing my pants at the time... The wheel locked solid and i had to brake to a stop before i went into the oncoming traffic. Wiggled the steering wheel and it freed off- drove home very very slowly. Anyways i removed the steering lock, ground off the tongue that engages in the column, and refitted- a steering lock is not going to stop someone stealing my landy. BUT This morning it happened again as i pulled out of a side road. This time i noticed that it was because the steering wheel was fouling the column shroud. I really dont see how i can adjust this to avoid it happening, the shroud just fits in its place. And why would it have suddenly started to happen? Previously to the first event yesterday i had not touched anything in that area. Any suggestions from the team? Thanks *BTW this is a B-reg 90. 1984? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 28, 2009 Share Posted August 28, 2009 As removing the lock has not cured the problem I would jack the two front wheels off the ground and inspect the entire system with an assistant turning the steering wheel from lock to lock. That way you should be able to track down the problem without resorting to guesswork. TBH with something as safety critical as this I would not use the vehicle until you have sorted the issue. Quote Link to comment Share on other sites More sharing options...
jbs Posted August 28, 2009 Share Posted August 28, 2009 I have just 2 days ago removed the shroud to stop one hell of a squeak as it was driving me insane, what it turned out to be was that the top of the shroud where it met the small indented ring that's part of the moulding of the plastic steering wheel was coming into contact with the shroud-ie: the raised bit's on where the two pieces meet at the top end of the shroud every time you turned the steering wheel it squeaked like hell, i took a hacksaw to the both of them and removed the raised bit's which does'nt actually affect it at all as you can't see it anyway-this all goes back together as it should but minus the sticky up bit's i now no longer have a squeak and life is more enjoyable with my truck Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted August 28, 2009 Share Posted August 28, 2009 also check the column UJs as they may be binding, you could remove the shroud and see if that cures it, it may have just vibrated loose Mike Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 28, 2009 Author Share Posted August 28, 2009 After speaking with my brother he said it could be CV's? the time it first happened last night i had just removed my front prop to troubleshoot yet another vibration that had developed, and was actually out testing to see if the vibration had gone. The front prop is still not in place- could this be related? I have been thinking about this and even if the column shroud did catch surely with a fairly good heave on the wheel it would just snap and i'd be off again? I have not been able to straighten the wheel at all in either instance and it has only freed up when i have slowed to a crawl... Oh, and the vibration is still happening... at around 65mph. This was found on my way to work before i realised the steering was still funky. Things done to troubleshoot this vibration (and my last one) have been: replace TRE's check and adjust swivel preload rotate wheels about to see if issue moves around car check steering damper check toe. Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 28, 2009 Share Posted August 28, 2009 Oh, and the vibration is still happening... at around 65mph. Things done to troubleshoot this vibration (and my last one) have been: replace TRE's check and adjust swivel preload rotate wheels about to see if issue moves around car check steering damper check toe. I really really really would check the steering column linkage, particularly the universal joints. Also, make sure nothing is catching on the UJ clamp bolt ends. The only other thing that springs to mind is to check nothing is fouling the swivels (gaiters?), TREs, drag and track rods. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 28, 2009 Author Share Posted August 28, 2009 Thanks Errol- i am currently at work, but when i make it home (very slowly) i will jack it up and check the steering UJ's. i have had a look already and could not see anything that might foul anything, but that kind of thing is always better with two people. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 28, 2009 Share Posted August 28, 2009 I had a similar thing happen in Newbury - round the roundabout, steering wouldn't turn, round the roundabout again and finally onto it the steering freed off, and I drove home up the motorway (minimal steering). Stripped out the hubs and found this - Same thing on a Disco On both vehicles the steering was momentarily jammed. Les. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 28, 2009 Author Share Posted August 28, 2009 Thanks Les! I made it home and will checkout the CVs quick sharp. Looks like the series 2 will be getting another airing! Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted August 30, 2009 Share Posted August 30, 2009 On another note...wont driving around with the front prop off cause the centre diff some bother?? Quote Link to comment Share on other sites More sharing options...
Joe 90 Posted August 30, 2009 Share Posted August 30, 2009 i would say definatly cv prob this would give vibration prob to. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 30, 2009 Share Posted August 30, 2009 On another note...wont driving around with the front prop off cause the centre diff some bother?? I can't see how, unless it's gear 'thing'. Considerably less load on the diff with no engine power to it. Les. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 30, 2009 Author Share Posted August 30, 2009 On another note...wont driving around with the front prop off cause the centre diff some bother?? Well it would if i attempted to drive with the centre diff operating- it would be spinning like crazy! I have it locked so there is in effect no centre diff a la series. Quote Link to comment Share on other sites More sharing options...
