zim Posted August 28, 2009 Share Posted August 28, 2009 Gents, At work we used to have quite a few 1" allen keys, which have slowly been cut down to short stumpy's and welded into bolts in order to remove them. Thus we're running out quickly ! I've been looking with our storeman, but none of the companies we deal with seem to stock them ? Can find 24mm and 22mm from Gedore and Proto don't have any other big ones. Ideally i'd like a source for lengths of Hex bar, which we can then cut to length for use with impact drivers / welding in. The main use for them is to bolting two pump parts together with 8 bolts and then tighten to 1,800 lb.ft then left for years being heated, cooled, wet, dry...rusting away - then management wonder why we break tools stripping them LOL Price is not an issue. Cheers Gordon Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 28, 2009 Share Posted August 28, 2009 Macreadys stock all sorts of sizes of hexagon bar, sounds like you might be wanting En16, or 605M36 to give it its new EU number...... Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 28, 2009 Share Posted August 28, 2009 1 inch keys (sit down first): Linky - yes that's a 14" Allen key I can find 36" lenghts of stainless 1" AF hex, but I guess you might count as an unusual post code: Eblag linky Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 28, 2009 Share Posted August 28, 2009 I have a couple , used to use them on idler wheels on trencher booms , IIRC I got them from my local engineering supplies . Quote Link to comment Share on other sites More sharing options...
zim Posted August 29, 2009 Author Share Posted August 29, 2009 1 inch keys (sit down first): Linky - yes that's a 14" Allen key I can find 36" lenghts of stainless 1" AF hex, but I guess you might count as an unusual post code: Eblag linky cheers....now to get our storeman to find a supplier to get some off! don't worry about the price LOL when you see some of the basic stuff we buy which cost stupid amounts just because it's for "offshore use" ! G Quote Link to comment Share on other sites More sharing options...
